  • Replies 237
Sorry Sydneykid for the late reply, as you asked i have been gathering infomation to back up my claim. From what i understand you work for a race car team, use motec in your race cars and are very knowlagable in you area. I am prepared for your critcism and happy to reply, as you keep the thread positive. unlike like the other dicks here.
The wolf is a better computer because
1. Price, compared to the motec of simliair features the motec would cost over $7000
2. Idle speed control
3. it is a true plug and play
4. from exprience the fuel delivery
5. does not need CDI modules to run the coils properly.
6. the wolf has 2048map points, motec 1048
RNS11Z, i do have cams in the head, 256 in 264 ex, i will confirm mph on wednesday.
TIMMMAYYY, (acutual Pimp) give me a break you ****ing retard, i will answer your questions when you are polite enough to answer mine.
ronin6 your opinion is well founded, the wolf has very basic data logging, an apsolute must for racing.
rev210 :D
raist60, smoke the coils, i will keep reading, ???????? no idea im not running at over 90% duty cycle.
dnb i would love to , my car is open for inspection, changing injectors not easy, lots to remove.
IMACUL8, i will talk it up, do you have a motec?, if so talk it up. clown
INASNT yes im a wolf salesman, lol. did that take you long to think up.
R32-GTS :D
INASNT another quality installment, do you think before or after you dribble.
BU5TER calling my self not the best drag racer would be to oposite of arrogant.?
RB20LagWagon cry cry cry, yet again.
my car is for real, sydneykid hope this is enough.
tristan
And what do we all expect to happen when he does, he's never been to the drags before ... hell it took me 6 months to get times that were 1/2 respectable out of a 400+hp car, it is not easy at all in a RWD how about we pressure him less and let him enjoy his car and after a few months of racing we have a look at his mph and judge it then :D
I for one don't want to see a nice skyline end up in the wall
there has been way to much pressure placed on tristan
none of this is his fault
his car makes that power full stop. it hasnt done a time full stop. he wont drive it to a time full stop. those are facts, **** the excuses and the arguing, what happens happens.
its a shame tristan is being used as a pawn by others to create arguments or to show off about how good their products are.
Good luck racing it, mate. Post your progress. I will suggest that the mph will be a better indicator of the cars' hp and potential ET's for the first while until you get a handle on the beast.
Adrian
A close friend of mine is one of the directors(owner) of AEM (advanced engine management) the manufacturer of WOLF ecu's.....I will have to commend him on his work next time i see him :)
Maybe he can hook magic1 up with a part time job :)
Magic good luck at the strip, what tyres and suspension setup will you be running?
Now I definitely think you aint running 370cc injectors dude. Wow! Less than 90% duty cycle on a 370cc injector (which makes 333cc best case) with 300+ rwkws.
CAWWWW!!!!
Ok so i got bored enough to actually do the maths and this is what i got...
Inj CC/Min Inj lb/hour Hp/Inj BHP
370 35.23809524 70.47619048 422.8571429
550 52.38095238 104.7619048 628.5714286
I got the formulas from http://www.rceng.com/technical.htm
Im no mathemagician just wanna show you what the maths says.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
