There are no "Specs" available for a Cefiro, closet would have to be S13 Silvia. I know they are listed on most machines as I just had mine done.
Like too_much_boost said, post up your itemised bill if you have one, $700 sounds reasonable though.
  • Replies 199
wtf specs for a wheel alignment? very strange? unless you specify something they will generally even up the camber if possible, set toe to neutral or in a little if you are running a lot of camber to reduce tyre wear.
Final bill was actually $635 - they must have seen me and felt sorry for me and charged me less :) I think that's quite reasonable.
They did a great looking job which I'm very pleased with - only thing is I have an unidentified white powder on the catch can (too much partying from the engine bay?) and a helluva lotta spray dirt/mud inside the engine bay (between the engine and fan belt kinda area) which I don't remember having when I brought the car in.
Probably just dirt from the car sitting around while they were water hosing their garage - I hope :)
I'm disappointed with the "no specs" thing, whatever that is, it's not exactly a stock car but they said it's not in the computer? I told em use the specs for the silvia cos it should be the same they said no prob come back next week for $80 << that seems like a bloody good price if they're doing toe/camber/caster/the works which pedders wanted (i think) $120 for. So I think I'll go back next week with my settings. I'd really love to have all my settings written down so I can just say this is what I want for sure - anyone care to suggest some numbers for toe/camber/caster etc?
Apperantly they said I should also get me one of these things as with the rear camber kit installed my rear wheels sits 'out' a little bit-
The rear feels ... different with the pineapples and camber kit installed (mostly probably down to the pineapples). The new plugs seem to make it run nicer too - MUCH nicer. I like it so far but won't be able to see it in action till it's registered.
While I was there a guy with a GTR was getting a twin zorst system installed and I noticed he had a nice kakimoto muffler... I told them I'd like to purchase from him to fit on my car - which should make a little less loud without making it crap on open throttle. fingers crossed on that one :cheers:
Next installment: Engineering certificate ;)
Hey, If it's a older cefiro w/ a zenki harness you might want to check the ground to the back of the alternator. Another thing is there is a fuse in the engine bay, marked "main" you might want to check that. When the ground broke off on the back of mine, it blew just about all of my fuses, and melted a few relays. Did a check light (looks like high beams backwards) come on right before it caught fire?
Got my wheels aligned yesterday and got a before and after sheet of the settings. Thought it'd be good for a laugh-
Before
Camber L -4.11 R -3.07
Caster L 6.34 R 6.50
Toe L 7 R 7
Rear Camber L -4.04 R -3.22
Rear Toe L 6.0 R 6.0
After
Camber L -1.32 R -1.26
Caster L 7.33 R 6.52
Toe L -.05 R -.05
Rear Camber L -0.57 R -1.00
Rear Toe L 1.1 R 1.1
Question - after they've set it up why did they set up each side slightly different?
Car feels very different now. Better overall at mid speeds but in slowish (2nd gear) tight corners the car kinda bumps through the corner, keeping the grip like crazy but bumping through it... I'm not sure if performance wise it's the quickest way through the corner but it feels tough :)
I will have to "test" properly at a track - which I can only get to when the car is registered. Still. Feels alot nicer now.
Yeah it is mechanical and yeah it's very tight so tight corners it skips HEAPS... whole car lunges up almost.. It just wasn't noticable before the alignment as much because the car felt like it sat more on the front wheels (with 4 degrees neg camber it makes sense).
Now when I go round the same corner it's not like the rear "slinks" after the front as much, it's more like the front falls into line where I want it to go and the rear half slinks and half bumps into place.
Might be the combination of wheel alignment and pineapples :)
My only thing is the garage said it's a 'sealed diff' and they can't change the oil :
When I get it engineered and rego'ed I'll be able to "test" more.
Well with rego out the next step in engineering will be getting documents from meggala for proof of purchase which he is sending tommorow woot!!
Armed with that I should be able to get through engineering next week and hopefully without any major hurdles there :
Finally someone said what I was thinking. *sigh* why oh why can't I ever seem to find a decent garage!?
It would be extremely unusual to have a diff whose oil can't be changed :) However, the easiest way to check is to stick your head under the car and look for a drain plug on the (rear, I assume) diff. If its in the standards R200 enclosure as per a lot of Nissans, it should be dead obvious.
LW.
  • 4 weeks later...
Was taking my car for a run yesterday (to keep it running nicely) and when I pulled it out of 3rd to put into 4th.. well.. something felt very very bad.
I had a hard time pulling it out and now 4th feels very squishy, and while it stays in there and seems to be putting power to the ground but it feels very very wrong (squishy/soft/no defined clicking in). I can push it out from 4th with no clutch at any rev quite easily too.
lol
Funny thing is silver my car is running better than ever.
It's the most reliable it's ever been, the cleanest and the best setup.
All I need now is engineering, blue slip, pink slip and I'm laughin.. my 4th gear is behavin now. So after that I'll try to reco the gearbox and that's it.
It's just that to get this far it's cost me too much and I've run out of cash for engineering+rego lol
weel good luck with it, lets hope soon we'll get to see it doing what it was built for
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
