imo, what does 3m of 2.5" pipe have to do with it when in the end its just into the atmo,
i mean basically having say 4" full exhaust (just to make it plane obvious) thats basically the same as the air being dumped straight into the atmo.. i dont get how it could be easier to have air "sucked out" when it all ends up in the atmo in the end.
  • Replies 98
Just opening up the exhaust is not necessarily the answer. The extreme would be to remove the exhaust system altogether but, for those of you who have experienced it, if the exhaust breaks near the manifold, all power is lost.
For a normaly aspirated (non-turbo) engine in particular it is important to retain a certain amount of back pressure. The reasons for this are all to do with exhaust scavenging which is to do with negative pressure pulses reflected back up the exhaust manifold to remove the last of the exhaust waste from the engine.
Hi [D4RKS1D3],
How much it set you back? Which one is it from this list..
http://www.magnaflow.com/02product/shopdis...one=main&id=386
Anyone know whats happening with that group buy?
cheers
chicane
http://www.magnaflow.com/02product/shopexd...one=main&id=764
Thats it there. cost about 450 for the muffler, and about 300 for the rest of the install. i do however have a feelin that i got a bit ripped off on the price of the muffler, but i didnt realli mind cuz the bloke rushed me thru and had it all installed in a couple of hours the following day.
The group buy has fallen thru i think. Not enough interest and communication problems with the supplier i think.
my car had an HKS dual dragger when it was imported, far too big and far too loud - absolutely useless, it was more suited to a GTR or GTST...
needed to change it for compliancing so I had a stock exhaust put in (still have it today) and the stock exhaust sounds absolutely CRAP, but it definately isnt quiet.
illusiVe - I've already posted a link to this site in this thread http://www.miata.net/garage/KnowYourCar/S4_Back.html Go and read it and learn all about scavenging
As for my muffler, I have a universal, large bodied, mild steel, 2.5" straight through muffler. Cost me $110 fitted and have proved (on the dyno) that it produces the same amount of power as my old TRUST muffler.
Have spent sometime reading throught this thread, as I have been thinking of changing my current exhaust, to a more straight through system. Currently I have jasma approved system with extractors (6,2,1), 2 1/2" stainless exhaust system with no cat and two very large mufflers (not the straight through sort). I was thinking of putting in a couple of resinators and a straight through type muffler, in the hope that it might improve the flow of exhaust gasses.
A friend sent me this article which I found quite an interesting read, looking into the importance of exhaust gas flow and looks into the back pressure thing too.
what size is the standard NA exhaust?
Mine was 2 1/4 inch from the factory i think. So basicalli you open it up 1/4 of an inch when movin to a 2.5 inch system. The onli thing that realli holds back your exhaust is the mechanical(?) muffler which is meant to baffle sound via redirecting exhaust fumes.
i think thats what the standard muffler is called. It just has the air looping back and forth thru a series of tunnels. if that makes any sense. where as a with a straight through muffler, its just a straight tunnel.
_________________
| _______________|____
| ( __________________ <-----exhaust
|_(____________ ) |
_______________) |
|________________|
In a standard exhaust then the fumes are "baffled" through a "mechanical" eexhaust and this results in restrictions.
__________________
|_________________|__
____________________ <----- exhaust
|_________________|
In a straight thru exhaust their is no restrictions to exhaust
nice ascii work [d4rks1d3] hehe.. ;)
check http://auto.howstuffworks.com/muffler3.htm ppl.. some go around in the fashion like d4rk mentioned, some go thru a more 'inline' series of sound absortion material/chambers etc, but the gist of it is the same.
I spoke to an exhaust shop (perf exhaust in ringood) about a muffler today. I told him how I want to go to a quieter (ive got a noisy rev-flow muffler on there now, and 3" pipe from bends to the muffler) one and he said a canon style (round) won't be the ideal one. He recommended an oval style one. Also quoted about 380 for a maganaflow oval one, but im not thinking only maganflow, but any good brand (post if you can recommend) which will quiet it down a bit, but not strangle it (and have _some_ noise when on the throttle).
Cheers :D
chicane
anybody else care to reply to this thread and mention anything I should look out for when getting a new muffler on my R33?
Cheers,
chicane
An internet forum is only as good as the quality which is contributed..
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
