Series 2 R33 GTSt, RB25DET, 188.89 rwkw or 253.3 rwhp.
Stock motor at 170,000 k's.
Stock turbo at 12 psi :EDIT:
900cc JECS injectors
Z32 afm
walbro 341
600x300x100 front mount
Power fc
Pod filter
HKS split dump
3inch front pipe, stock cat, 3 inch kakemoto catback.
BP 98
Tuned by me and checked by Rotomotion.
r33 s2
hks 2835 pro s
3" exhaust from dump
unknown catco cat
nismo 740cc
yellowjacket coils
bcpr7es plugs
z32 afm relocated to cold pipe
4" pod to turbo
powerfc
bp98
china cooler
koyorad
nismo fuel pump
240rwkw at 19psi drops to 16psi
something is restricting making anymore power, but happy with 240 for now
will post dyno sheet later
Stock rb25
FMIC
MICROTECH LT12s
3INCH TURBO BACK EXHAUST
8PSI
190.4kw
with a bad missfire, at 10psi it was making 180kw @ 3700 revs with a bad missifre, going to replace coilspacks and retune, MICROTECH ftw =p
Stock RB25 Motor
Go fast bits....
GTX3076 .82
Link G4 ECU
FMIC
3" Stainless turbo back
Splitfire Coils
Pod / Custom Air box
Gizzmo IBC
Sard 840cc injectors
294rwkw @ 18psi - Left it there as still running stock internals. turbo capable of much more.
r33 s2
hks 2835 pro s
unknown catco cat
nismo 740cc
yellowjacket coils
bcpr7es plugs
4" pod to turbo
powerfc
bp98
china cooler
koyorad
nismo fuel pump
0534_001.pdf
Got my car tuned but its going back soon.
Anyway its an R33 GTST Series 2 with the following:
Unopened RB25DET
HyperGear ATR43SS-2
3" JJR Bellmouth dump
HKS Hi Power Silent exhaust
Yellow jacket coils
NGK Copper plugs BCP7RES gapped to .7
Genuine HDI FMIC
Venom 5" body 100cpsi cat
Nismo 740cc injectors
Bosch 040(was failing during tune)
Nismo FPR
Greddy profec b spec 2
3" metal intake with Apexi power intake filter
Power FC tuned by Advan performance
Made 244rwkw on 11.4psi. That is with the boost controller set to 100%. That is as much as we can get out of it. With about 15psi, we should see about 270rwkw and 17psi about 280rwkw. 20psi should see 300rwkw on regular fuel pump.
Ive fitted a GTR fuel pump in there to fix the fuel pump issues. Probably will swap that with a brand new 040 pump or run it as a lift into a surge tank. Last printed dyno shows about 238rwkw on 11psi, should have printed the previous runs :P
Got it retuned, the AFR is perfect. Running more boost 15 low 19 high. Oddly enough high boost is seeing 250rwkw low boost is on about 217rwkw but low boost feels much stronger than the original 244rwkw on 11psi... Mind boggling. Intake pipe might be a huge restriction. Making close to 700nm of torque, it absolutely rips my face off compared to what it was before. Very impressed with the thorough tuning work done by Jez and bordy. A dyno gives you a number, but what you feel on the road is what counts and wow this is amazing. Just driving home on low boost the lift on the front end was intense.
93 R33 GTST Rb25det with forged pistons (factory compression) and stock every thing else.
550cc injectors
Z32 AFM
HyperGear ATR43SS-1PU turbocharger with updated compressor profile.
3inch turbo back exhaust
Ebay cooler
Nistune chipped ecu
3inch metal intake pipe to air box.
The most power made was 287rwkws, and average was 280rwkws @ 17psi. Very consistent result with consecutive dyno runs.
93 R33 GTST Stock bottem end rebuilt. Standard head/cams.
JJR Cam gear
720cc injectors
tomei 500hp pump in tank
power fc w/z32 afm
GTR intercooler
Greddy plenum
GT3076R .82 external gate turbo
Tial 44mm gate.
Stainless high mount manifold modified by rob at creatd.
Straight thru 3" exhaust with a Trust PEII cannon.
297.7kw on bp ultimate 98 @ 20psi.
Unbelieveable response and control.
^^^ Add some graphs ^^^^
Finished mine ages ago probably should add it..
t67dyno.jpg?t=1308909591
t67boost.jpg?t=1308909571
More in it but settled here due to injectors near max and valve springs getting loose up top.
Internally stock Rb25DET 170000ks
t67-25g
6boost
tial 44mm
freddy plenum
z32 in cooler piping
power FC
profec B II
740cc highflowed stock injectors
bosch 044
3" exhaust
Adjustable EX cam gear
Splitfires
exceedy 5 puk clutch
E85 (trent tested it at E65) Springvale stuff
Basic engine rebuild, arp head studs, commetic 1.2mm HG. Abit of porting to the head.
Spot-on inlet manifold (stock throttle body ;))
6boost exhaust mani
pro boost gate
garret 3076
lt12
550cc inj.
pump/tol 70/30
456rwhp @ 22psi.
R34 GTT 1997 w/2000 model 25det neo motor
Std internals (as far as i know :s)
Hybrid FMIC
Turbosmart stealth series plumb back bov
Splitfires w/iridium plugs
Walbro GSS341 or 342 cant remember which
3" advance front/dump
Bokka 3" 100cell metal cat
3" stainless cat back 1 res 1 muffler
Nisstune
10psi (spikes to 12 and drops to 10) rb20 actuator
201rwkw and a touch over 550nm (peak) of torque on the jaustech dyno,injectors,afm and turbo at the limit.
550cc injectors
Z32 AFM
Ebay cooler
Nistune chipped ecu
BP 98 Fuel
ATR43G3 Rb25det bolton version internally gated.
We also had a customer run the same turbo on e85 making 347rwkws with factory setup. you can find his reading in our high flow thread.
330rwkws @ 23psi using manual boost controller
320rwkws @ 20psi. No boost controller, straight of high pressure actuator.
Track footage
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
