  • Replies 1.2k
You ppl are scaring me all this about pink shirts and Leather, and the name of our team for triv night.
Not that there is anything wrong with that sort of thing
You bringing the entertainment 2night Shaun?
Johnny had an Avatar up earlier that looked amazingly like your freind :wassup:movin' n grindin':wassup:.
Stop Playin with your Avatar Johnny - trying to work mate. Your making it hard!
We know what happens when you see half naked girls. No I am not bringing the entertainment tonight, she is busy and the other mate is not answering his phone.
Now what is the point of having a mobile phone if you never carry it with you. If you dont want to talk you just turn it off.
Can't make it this week either, I'll come eventually!
Off to sunny port Stephens first thing in the morning, then to Falls Festival for new years.
Merry Xmas all, catch you some time in the new year. Looking forward to taking many photos with a swish new digicam santa is getting me!
j.
Well J. Enjoy urself big time over Christmas.
:whip:
Remember your new digicam will work outside too mate!
Bahahaha :bahaha:
j.
Thats cool, the barmaids will thank you for that.
Andrew (Veil slide) is going to be late. No Madam Lush n Stu this week either.
I am sure they will thank me for that. We all have shockers. On the way home he sobered up a bit and went oh **** i am a dickhead, and he had a bit of a winge about his actions, i found it all rather embarasing but funny at the same time :Oops: :Oops: :Oops:
I should get there about 8ish hopefully.
Hey - he wasn't bad at all. I walk in sober and they slap me first then give me a Bourbon!
R
I would like to say that that was a great turn out for triva even though we did come 3rd last it was a good effort from all. I would also like to apoligise for going a bit to fast around the big round about and getting in a weee bit of trouble for it SORRRY all. Have a marry Christmas and a happy new year to all. Hope I wll c u all in the next year or sooner.
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
