  • Replies 1.2k
does this mean that you will start showing up again richard :P
anyways i will be their for sure this tuesday
Leigh
IT'S TRIVIA - That's right TRIVIA Night at the Jerra Club every Tuesday night.
It Kicks at 7:30 and its FREE. Prizes come in Glasses, Bottles and Cartons
C'mon get social with your SAU Crew and sign on.
Show up about 7ish. Depending on numbers Teams can be organised on the night
Q. How many liners can fit in the Jerra Car Park?
Q. How many SAU members were bored last Tuesday night?
Get it all together folks and get down.
The weathers getting warmer, the bourbons getting colder and the wimmen OMG I hope they show up too.
NO pensioner jokes aite - it's not bingo!
and OC isnt on either gay boyz
SOFTttttttttttttt :( its worth the trip even just for the meal
i will definatly be their this week.
yeah your right leigh the food there is awesome hey! but for some reason ive never paid for one meal...? :(
:lol: jks :)
Edited by SKYLVIA
Me + E will get there for a short while tonight-I'm still trying to find a replacement backside,as mine is somewhere between Phillip Island and here...LONG day in the saddle today! Just got home...
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
