Hey guys,
Just about to puchase an EBC but not exactly sure whats the go with all of them. HKS EVC, Blitz DSBC, Apexi AVCR, Trust Profec-B... My car's never going to run over 1.5 Bar, and i've got a feeling that all the flashy lights and cool displays will eventially become a little bit of a gimmic, so the Blitz is looking the option.
What i'd like to know is peoples experience with the different EBC's the troubles they've had (during install, useage, etc), reasonable limitations of the models, and if the flashy displays have had the novelty worn off after owning it for a while.
Thanks guys!
https://www.sau.com.au/forums/topic/56344-ebc-choices/
Have u had a look at Turbosmart? I have the E-Boost installed which also acts as a Boost Guage. You can have three boost settings and it is very compact and easy to set up. I had mine tuned within 5 minutes driving on the street, by just following the instructions. E-Boost can also be cheaper than some of the jap brands.
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1092554
I've had a Blitz SBC-ID.
Holds boost up top as it learns the boost curve and duty cycle that must be set in order to achieve the boost setting you enter.
You can setup one of the 4 or so channels as a scramble channel that spikes up a little when you first punch it or change gear.
Thats the way I used to have mine set.
Manual mode that would make slightly more boost for the first second or so then the auto mode would take over from there.
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1093166
Had an apexi avc-r... was easy to use and install but had a little boost spiking problem on 12psi plus settings.... Was a little slow to compute the spiking and tune it out...
Must get a dual sol... much better for holding boost...
Got a BLITZ SBC-i-D III now... yet to install... next week
Did all the research and it seem to be really good... Will let u know...
Plus its single din height and 1/2 din wide so it fits a treat under aftermarket single din headunit in a 33...
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1094325
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
