Originally posted by adam 32
lowest structural part has to be 100mm off the ground (this is normally the chasis rails) remember the exhaust is NOT structural and therefore doesnt count...
see your pm for full detials
Are spoilers classed as structural? and what about clearance from the top of the tyre to the body? If any one can clarify this it would be much appreciated as there is a LOT of uncertainty with measurements and clearance heights!
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85357
Originally posted by GR33DyMANGO
all i can say is totally radtech! heeehe
Radtech??:confused: ahh maybe im just gettin old
BTW: whats a good paint job like that worth? i could 'prolly' (i use the word tenatively) do it myself but i prolly couldnt be assed:drooling:
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85475
daniel
there are 2 measurements that are commonly used, ground clearance and centre of axel to wheel arch.
1) the car must be 100mm off the ground from any structural point, bodykits are not structural. normally the lowest point is the chassis rail.
2) there is a certain distance that needs to be met on every car from the centre of the axel to the wheel arch. on R32's (when i had to go thru compliancing) it is 350mm. this varies from car to car and is about 10-20mm lower than the std height.
when going over the pits it depends alot on the overall presentation of the car, if it is a fairly tidy looking and 'tastefully' modified car then you can normally slide through. They tend to pick on riced up cars which are rediculously low or loud...
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85497
Guest GR33DyMANGO
Radtech?? ahh maybe im just gettin old
haha.. my friends made it up when were skating at the leederville skatepark about 8 months ago. my mate skated around it a motorbike jacket and helmet looking totally homo.. we all laughed and someone called him radtech. if u r REALLY radtech.. then you;re radtech invincible.. haha.. sounds pretty silly.. but it has too many memories.
then last week.. my little brothers friends have this tv show on channel 31, mondays at 7.30pm called EXTREME WA... and they said radtech about 8 times.. we;re all trying to make radtech a new 'cool' word.. haha.. we do some pretty crazy things.. hehe..
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85529
Well hopefully they look upon my car favourably :P
I really can't be bothered with those sorta hassles.
It's only really got an exhaust and it's not loud at all so I should be ok. Doesn't even have a pod filter :D
Tomorrow morning will tell hehe :P
Cheers for the kind words Justino :D
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85589
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
