A mate in Brisbane saw an R34 this week with GTS-t badge on rear.
I rang a brake & suspension shop to get my brakes done, said it was an R34 & he asked me if it was a GTS-t or GTT.
GTST's have 310mm disc rotors & GTT's have 296mm - according to his brake manual.
That's all I know.
Its all weird. My Car is known as an R34 GT-T 2 door coupe. The badge on the back says 25GTt
25 being the engine, GT being most of the R34's and t being turbo.
Ive seen 25GT which are the N/A version.
The owners manual for my car doesnt list the GTST, only the GT-X (is a 4door rb20DEneo i think), GT-T 2 and 4 door and GT 2 and 4 door.
The difference between the R34 GTS-T and the R34 GT-T is that:
The R34 GT-T actually exists.
People can put incorrect badges on their car if they want to, like a GTR badge on a GTS-T.
Or have no badge at all (someone stole my GTR badge).
:D
R32 GTS-T = R33 GTS-T = R34 GT-T
R32 GTR = R33 GTR = R34 GTR
Guest RedLineGTR
R33 Grand Touring Sports Turbo - The 25 Stands for the 2.5 litre Engine.
Have a look if you still have the sticker on your r33 gts-t is states gts25t
R34 Grand Touring Turbo - The 25 Stands for the 2.5 litre Engine.
Have a look if you still have the sticker on your r34 gt-t is states gt25t
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
