hey guys/gals
i have recently puchased a r33 and i am looking to do a few upgrades. and
at current the only mods the car has is: 3" zosrt inc dump pipe and high flow cat, pod filter, blitz atmo bov, turbosmart single stage boost controller, apexi aif flow meter corrector(i think thats what it is???). before i bother doing any ecu changes i will be fitting a 600x300 fmic though.
now my question is once i have the cooler combined with my other mods (listed) what is the best way to go about tuning my car to get the most from the setup? am i better off with a complete aftermarket computer? a piggy back style computer or am i just able to have the std ecu remapped to suit? what ever i choost i want to be able to use for future upgrades as well so i was thinking about going to the path of either a piggy back or aftermarket ecu.
i have noticed that the apexi range is used very common amoungst rb owners, jus wondering if any of their products would be suitable for my aplication? if so which specific ones? as i have seen many mild and wild rb's using apexi electrical products.
another alternative which was suggested to me by a local tuning workshop was a 'uni chip' piggy back style computer, can anyone comment on the performance and tunability of these products? i was informed that these were completely retuneable yet keep all the factory ecu settings like cold start, air con, idle etc.
thanx in advance, and sorry for the long rant!
cheers1
https://www.sau.com.au/forums/topic/57143-best-ecutuning-options-for-rb25/
  • Replies 44
power fc is full stand alone replacement ecu. removes speed cut, boost cut and fuel cut, adjustable rev limit, fuel and ignition maps (20x20) and access to some other features that i cant remember
sounds pretty good, is it worth looking into some of the more basic products in the apexi range? not to sure what is what. is there a model that will allow adjustment of air/fuel, timing etc?
apexi safc II
www.apexi-usa.com
how good is the safcII? can anyone who has used or is using one with a mild list of mods (exhause, fmic, boostcontroller, pod) shed some info or recomendations?
would i need a full stand alone comp like a power fc, or would something like a safc II be quite adequate for my needs? and still be good enough to support a future turbo upgrade?
safc II is generally good for very mild tune of the rb25
front mount, boost controller, pod/cai box, exhaust and thats probably about it
once you wanna run bigger injectors, diff turbo, air flow meter youll want the power fc
you will get more benefits from stand alone like powerfc of course but its not always needed. the safc can be a cheap alternative, but remember you have to get the safc fitted and tuned. buy is around $450 then fit and tune prolly $250
the powerfc is $1100 delivered gives you all the features of safc plus stacks more
I had an SAFC in my car after i turned up the boost. Didnt really help much just saved me some money on fuel. I was getting pretty bad detonation. Then upgraded to a Wolf3d version 4. Have not had any probs since.
And yes there is a PFC that is plug and play but you will still need to have it tuned.
Steve
Go the power FC, easy to fit and tune, Never headr a bad report
When you fit your cooler, I suggest getting a plenum made up to,
If you plumb your intercooler up to standard intake manifold, piping is like 3.2mteres long!
With the plenum its under two meters and a hell of alot more responsive and torqey!
Have fun
id suggest against changing the stock plenum. there has been numerous threads and its been aruged over and over. the stock plenum is good for over 500hp and doesnt need changing.
the cost to change plenum to save a short amount of pipework is not worth it, its like .0023psi pressure drop from the extra pipework. you wont loose torque just a bit more lag in the system from the piping, the plenum will cost you $1000 odd, you can spend that money on much better suited products instead, likes cams, ecu, injectors, clutch
Have fun
when you say get a new plenum made up do you mean a completely new, larger flowing item, or modifying the stock plenum so the the throttle body is facing forward instead of towards the passenger side of the car???? as i have seen this done before and looks quite effective.
Have fun
Sorry wsln33, I gotta dissagree, the intercooler pipework length makes no diference to torque.
Using a 120 degree bend at the throttle body reduces the difference by more than 50%, to a bit less than 1 litre using 75 mm pipework.
To work out the throttle response difference the calculations are easy;
2500 cc X 5000 rpm / 2 (4 stroke) at 1.3 bar = 135 litres per second
So a saving of 1 litre represents less than 0.005 of a second
That's not a lot of lag to save with reduced pipework.
Not a good idea in my opinion, especially when you consider the potential to loose throttle response due to poor airflow distribution is far greater than that.:)
I'm running a Wolf 3D 4+ on the RB25DET I fitted to my GTS4. On crappy 95 octane and 10psi, pumping 180 kW thru ALL 4 wheels (probably 210 rwkW).
There is a straight plug-in replacement (like PFC) available for the R33.
r33steve, did you have the safc tuned? if so you didn see any benifits?
The only benefit i got was saving a little money on fuel and slighty reducing the detonation i was getting. My standard computer was running ridiculously rich. I wouldnt buy another one, Id go straight for a stand alone.
Steve
I have had an SAFC2 installed about 2 months ago and i must say it's the best money i have spent. Yes the standard ecu when boosted made it run hell rich and produced 160 rwkw with a nasty flat spot and then after the install and tune of the SAFC it was a healthy 189rwkw and no flat spot. Sorry to hear your results Steve but i must say im very impressed with my end result. Stock cooler stock turbo, 3 inch from dump, EBC set at 12 PSI.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
