Hi Guys
I have a friend who imports short shift kits (enhanced Cs copy) and I can get some good deals from him if I buy in bulk. This is the going rate
buy 5 for $145 each
buy 10 for $130 each
buy 15 for $120 each
buy more than 20 probably $110 each but we will see if there are that many takers.
Postage is usually $13
Here is the list of short shift kits I can get
R33
R32
Silvia/180sx
s14/200sx
If you guys are interested pm me or email me or reply to this thread.
Over the next few days/week I will see how many people are interested and let you all know what the cost will be. If everthing goes good I will then need the money from the buyers and I will get the parts and send them out to you guys. If everyone pays up quickly the buyers should get their strut brace within 7 days.
https://www.sau.com.au/forums/topic/57182-short-shift-r33-r32-silvia-180sx/
  • Replies 69
Interested in one for an R32 GTR.
A question: on the website listed at the bottom of your post it shows the price for a short shifter for an R32 or R33 as $145 - is that for one kit ?? It's just that I would have thought the price for 5 would be less than the price for one.....
If I bought all 5 myself then I can sell them for $145 each. Which I was doing a few weeks ago. But I decided make life a little easier and hopefully I can make the prices cheaper for you guys by having more money up front and buying in bulk. So this is where the group buy comes in.
I should really change my website. Thanks dude...
with the short shifters is the gear nob part removeable because i have a razzo gear nob that i would prefert to attach to the top as opposed to the silver bulb that it has in the pics. so it it possible to unscrew the silver one and is there a standard thread to put my old one onto?
Yes gear knob is removable. I was able to put my genuine skyline knob back on
Seriously it is really easy to install. Instructions shows you what to do. If you get into trouble then email me...
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
