Front ones - minimum $700 (AUD). Side ones when you find out get two sets Pleeeeze.
I got mine on the car when I got it. Out of Japland. Have not seen local shops withem. Doesnt mean they dont have em just that I have not seen em.
$700 omfg is that a spelling mistake ??? who would pay $700 for a set of side indicators :D
A pair of front ones for R32 $700. Side ones dunno neva seen em even on Jap sites. But there is really nice ones on that green BMW that parks out the front of my work. Hope they work late one night. He he he. J/K
Damn.....
Yea they look nice but, $700.... yea well shes mah baby so what the hell...
Where can you get dem from?
Sides, if seen people with em, but there dif shapes... so they obviously are useing ones off dif cars.. But i found a Merc with Clear ones, and also a Camry has em...Same shape just clear.
Guest two.06l
Hey all...
Anyone know where to get Clear indicator for a R32 GTST
Thats the Side guards and the front ones...
And aprox what they are worth.
Thanx :):D
we have a set of D-speed front indicators, paid $450 for them (new in box). Mazda 6 side indicators fit the sides and are $35 a side (hole in guard needs to be modified)
lol.....
Good work. BTW anyone know how much those 2 GTR's are goin for at ed's???
Im very keen on getting one
I Wouldnt bother. Rolling shells ATM went chrissy shopping 2nite! But seriously Ed can hook you up with the owner. Blue for sale the other is drivin by the owner.
If anyone is keen to upgrade from a 33 or 32 GTS-T I have contact with a 32 GTR with a fair bit of new gear running genuine 290rwkw's. New motor, turbs, brakes, wheels, rubber (Brand name stuff) and a fair bit more. Straight and clean. Was keen on getting it prior to the GTR I bought.
The Lads under pressure ATM with a new bubs and house. Should be a good buy. Originally adv @ 35k, down to 32k expect in the vicinity of 28k. PM me for a flyer.
R
its going VERY cheap actually stirlo.
but i wouldnt bother trade in Andrew, you'll never get anything like what its worth, especially from evo! just sell it, yours is a very different look for a 32 with that kit and someone will be bound to snap it up. but ask any of the guys with gtr's here, you have to be able to afford to fix them, and thats where the real slap in the face is, but i would definatly encourage you to go and check out stirlos, well worth it and cheap as hell!
regarding the front quarter panel indicators, the R32 didnt come out stock with indicators there, they are added at the compliance stage, so what fits on one may not fit on another 32, so i reckon if you find some that you like, find out how to get them and do it
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
