HAAHAHAH!!! YOU THE MAN!! :)
I have seen the 2nd but not the 1st..... where did that one come from Mister Media Mogul?
That was on the rollaboyz cruise over the weekend. Also guess who the person is that I am speaking to in the 1st pic??? Not other that Mr PVA GLUE HIMSELF!!!! Joe.... C'mon Down!!!
Cheers dude!
:( :lol:
So i take it this is b4 the incident with the white 33 that mr greenshirt is standing next to? same cruz?
Is this a photo that u took Skyzerr?, ran up the stairs to get it?
Or is that u doin a runner on the other side of the road? (bein the cruz ninja that u are)
Originally posted by Boostzor
Dammit im sending u the bill for my chiropractor Skyzerr:freak:
Wasnt she in another photo that 25 gtt provided or this his g/f?
Before you start making comments about her yes that is my gfriend.... :uh-huh: :)
It was actually the 1st cruise that she lliked...nice weather for it aswell! we left halfway just before that pile up it seems to get sumfin to eat... perfect timing it seemed! i didn't want another smashed bumper!!:uh-huh:
Cheers dude!
:( :lol:
well Dan spoiled it
i wanted them to guess it was joe :)
Originally posted by SeriesIIGTST
Far out! That white skyline in the 2nd picture looks like a clone of my car, only with a sunroof! That can only mean one thing....
NICE CAR!:D
See you all on Friday for da crooz
Dave:burnout:
Nah his was a non turbo... definately not the same as your beast! ... Joe showed me a few of the differeences between GTS and GTST... colour of GT badge near side indicators, front Brakes have no 'Nissan' Insignia on them.....
HJB:
Check out the crooze details under the "Events" section of Western Australia, up the top.
25GTT:
Ah okay, cool:) Hey, was one of the differences Joe was showing you four studs instead of five holding the wheels on? I was parked next to one with 4 stud hubs where as mine has 5. Both R33. Come to think of it, I did notice the badge was blue??
Cheers!
Dave:cool:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
