I have a set of wheels for sale came off a R33 Gtst (no guard rolling req)
They are 18x8 and 18x9 ANZ Voltek Hyperblack wheels.
The 18x9 deep dish style is no longer made any more.
Asking $1100. PRICE DROP $750..
Excellent condition.
Can post if desired.
https://www.sau.com.au/forums/topic/57276-18-voltek-hyperblack-wheels-adelaide/
Did you need to roll the guards to fit,  Do they scrub on the inside of the guards???
Not at all. Currently have 265 RE540s on the back.
The wheels are still on the car and can come off as early as next Monday if required.
I have a set of wheels suitable for R33 Gtst Skylines.
Asking $1100.  PRICE DROP $940..
Price Drop to $940..(Cheaper without postage)
VERY interested. Would these slip pretty much straight onto an R32 GTS-T? I'm in Adelaide so i can pick up.
Actually just read... there's no tyre with that right? Hmmm...
Still interested maybe....
Cheers,
Adam
Sending a Pm
Asking $1100.  PRICE DROP $840..
Price drop to $840
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
