Just want a general idea about what tyre pressure's to run for light track duties on normal road tyres
Tyres are Dunlop FM901's, 225x50x16 on 16x7.5" P1 Racing rims
Thinking around 36-38psi hot, but not sure, as I run them at around 36psi on the road?
Cheers, Chris
https://www.sau.com.au/forums/topic/57386-tyre-pressure-for-track-work/
yeah really hard will be good since they are road tyres, and have a 50 profile. Up to 42 hot I would suggest.
Pump em up to 40 cold, go out and do 3 hard laps. pull into the pits nice and quick and let them back down to 42 from 45ish they will be at. Easy :P
Well, to a point a higher tyre pressure helps your handling. The pressure in the tyre acts like a firmer spring/shock combo to give more direct handling, with lower pressure the car moves around on the tyres more.
But, over a certain pressure, different per tyre compound, they will start to give less grip as they get too hot. Road tyres (hard) can take much higher pressures, while if you were using something softer like r spec tyres they generally have a lower optimum temp like 34-36.
Cheers mate, it was good to catch up! Still in awe of the torque of the 3L, oneday I wouldn't mind a bigger motor.
Dump pipe still not done, been delays with the fabricators, so its going up there as it was previous, but running less boost for safety sake, will take you for a drive someday soon, I am working through christmas but have a month of mid january, so I will have plenty of time to catch up
Got my brakes on too, R33GTSt calipers, slotted 33 rotors and Racebrake Comp 9 pads up front and Comp 2 pads on the back, it stops awesome now - still bedding them in so it shoudl get even better
Im looking forward to seeing how your car goes....i wanted to go for a run with ya, ...
Dont, once you feel the wrath of the RB20 you will kick yourself for playing around with that truck engine of yours...it runs on diesel right:)
How are the comp 9s on ths street, bit grindy/noisy or not too bad?
LOL Troy :cheers: I actually pulled up the other day at the lights along side a b-double, and when we took off, i noticed i was actually changing gears at the same time as the truck driver :D No joke :cheers: ....
Ill have to get you to run me through your brake setup chris....might be worth doin ometime in the new year for myself...have you checked out if there anymore firewall movement with the bigger brake setup?
My clutch (os twin) gives a shietload of movement in the firewall when u put the clutch in...so much im a little worried about it, and may have to make us something up :)
Cheers, Chris
We usually start at round 28psi, with a target pressure of 35-38 (air) I have tried them higher but personally I don't like them.
Either way, it is a good way to learn. When they are where you reckon its OK, drop a few PSI out and note the difference.
The FM901's are a street tyre yes? they will like to be a bit tighter than a "r" type.
"Which way does the track go, and whats the lap record?" Graham Crosby
Have fun...
TT
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
