hey guys i got a rb26 with 350rwhp (in 2wd in a vl) atm on 17psi, with bigger inj, highflow turbos, pods, zorst, etc and i am getting the 4wd gtr sump enlarged and baffled as we speak and i was wondering what sort of power figures do i require a better oil pump?
whats the n1 pump good upto?
is it worth getting the n1 pump or another jap brand for the extra $$$???
im using the car mainly for street use and the occasional track day or drag meet if thats any relevance :rant:
cheers
Brad
ur stock oil pump will be fine for the power u have but i guess once u start making 300rwkw then oil pump should be considered, I would spend the extra money on an oil cooler, benifits from that are more than u know, i guess its not a matter of what hp is the various oil pumps limited to its more the point of how much u want to help ur engine?
does anyone know where you pick up and return the oil in an engine oil cooler?
they usually have an addition that comes from the oil filter location, just a supply hose to the cooler and a return hose back to the fitting. although no doubt it can be done differently.
as covered many many times the n1 pump is the same as the normal pump with a higher spring rate so it runs slightly higher pressure, you can do this to your standard pump for $20. Also if you are running an early r32 engine it would be wise to invest in a r33 on pump and a jun crank collar to address drive engagement issues the earlier designed cranks have!!!
so the N1 pump and the nismo high volume pump sold by nengun for about 1k are not the same aahhhh that makes sinces.So at wot level rwhp do you need to go to high volume pump ie tomei, jun, etc etc as i am running about 390rwkw and are about to upgrade internals and pump etc
pete
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
