*GTR Injector 440cc.....$350 ono
*Nismo 33 GTR height and dampner adjustable shocks,good nic....$900
*Omori guage ,Exhaust temp...$150
*Omori guage, Engine oil temp...$150
*Sparco steering wheel spacer, brand new....$100
*Z32 AFM with plug....$350sold
*Power FC for SR20..bought second hand and never installed, Unknown condition.....$500 ono
*HKS Graphic Control Computer--(HKS PFC F-CON) and wiring
http://www.hksusa.com/products/?id=688 ...........$350reduced
*HKS Injection Pulse Monitor (good with the F-Con).
http://www.hksusa.com/products/?id=729&rsku=0 .........$150
OR BOTH for $450
*Genuine 33 Vspec standard shocks..........$350 onooffers
*1 orange GTST indicator, leftover stuff from previous car..........$15
*Pair of orange GTR side indicators..........$30
*Prefabricated 1 cubic foot 12" sub box..........$15
*32 GTR manual in english on CD...$20 reduced
*Home made 2 x 12" box for 32,Home made 2 x 10" box...$20 each
*JVC Kameleon CD player with blown internal amp (new $1300)...$250 works perfect with external amps.
*Blitz Badge..........$20
*Clarion eqalizer...$40
*altec 2 chanel amp...$50
*Tiny steering wheel...$80
*Genuine plastic 32 GTST sideskirts....$250
*Razo gearknob...$40
*Niken gearknob.....$30
*QLD personalized plates
40RCN, silver on blue..........$1000
GTR44, silver on black..........$470
51CKR, silver on purple..........$650
*LT50 4 wheeler 50cc 97 model....$1000
Too many things to post up all pics so email me and I'll send some.
I'm after a twin plate clutch for a 32 GTR so maybe a deal can be struck on something.
[email protected]
https://www.sau.com.au/forums/topic/57711-huge-cleanup-sale/
interested in the power fc for the sr20 any idea wat year this is to suit?? where are u located?? all ya have to do is plug it in if it doesnt start its either ***d or not for my sr20... i dont get on here much so use my email
email me as much info as u have [email protected]
Cheers,
Danny
OR BOTH for $450
*32 GTR manual in english on CD...$30
[email protected]
is the power fc for 96 s14 200sx??/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
