I imported my car before you could get them im withiout having the air con gas removed so atm my system has no gas in it and the little bottle is sitting in my back seat.
Ive heard that you need to replace all the seals on the system as the R134A gas that they use these day will eat through the seals on the system set up for the old 12A gas.
Firstly is this correct?
Secondly if it is how much am i looking at and can anyone recomend a place from the southland area that will do it and not cost me an arm and a leg.
Thanks
Jason
https://www.sau.com.au/forums/topic/57928-air-conditioning-regas/
The seals should be replaced if the job is done properly, plus the receiver-dryer (the old one is probably that little bottle you mention) and they change the oil in the pump. Hoses don't usually need changing if they are in good nick.
You are looking at about $250 - that was what I was quoted, but my car came into the country charged with R12 and still cleared customs. Not a word from DEH.....yet (knock on wood ;) ).
I use a mob called Kar Air in Ferntree Gully, but that's probably a bit far for you.
Auto Cooling Clayton Pty Ltd
10 Westall Rd Clayton VIC 3168
ph: (03) 9562 4811
I was looking around about a year ago in the same area, and these guys were the cheapest I found, and the most professional. Gave me very good honest advice...
They also make intercoolers, and re-do end tanks and stuff...
Oh, and BTW, he also told me he has a replacement gas for the older type, so it wont cost as much...
nevermind managed to fidn a place on warrigal rd that will replace the bottle and the seals and regas for $160. not bad at all so im booked in for next wednesday
Cool, my car is in that areaq at the moment...and my car needs re-gassing as the mechanic didnt have time to do it after changing the engine in my POS.
Can you post phone/contact details:thumbsup:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
