Ok, got the S-AFC tuned, and picked up an extra 15kw and 60Nm at the wheels. Now, this is weird because the power seemed to be quite low (166kw after tune) but Mark said that it was quite a good amount of power and that usually the other Skylines he tunes come up with around 145kw. But also, the torque seems to be monumental, it was around 640Nm!
The thing is he did the dyno runs in 3rd gear, because he said in 4th you run into the speed limiter. Am I right in thinking that having a higher ratio (3rd gear) would increase your torque and decrease your power, when compared to a lower ratio (4th)? It seems like that to me anyway, when considering the figures and Mark's comments about them. Also considering that the stock torque of an R33 GTS-t is under 300Nm, there's no way that I'm running double that right now.
The car still blows a bit of black smoke, but that's because he deliberately left it running a bit rich when I have the hammer down so that it doesn't ping on really hot days. The PowerFC as far as I know has temperature compensation so it can be eventually gotten rid of once I can afford that.
Next step is going to be a custom dump pipe, with dyno runs before and after (he said he likes to show the customer where their money is going - big thumbs up for that!) and eventually, either new intercooler plumbing or a new intercooler (my current fmic is very average).
Watching my car get sideways on the dyno was a damned good sight indeed :)
  • Replies 63
great results, but its a little bit of a shame they are in 3rd gear...!
wot a/f ratio was the car running stock, and wot was it running after mark tuned the safc?
seat of the pants, how does it feel?
how much did mark charge you for install and tune?
i'm going to see mark tomorrow morning to enquire about a few mods. hills apparently do a front mount kit for $1800 that is a micks metalcraft fabrication - can anyone comment on this kit? this is fairly reasonable value considering a jap kit will be close to 2k depending on who you take it to...
am also looking at a dump pipe and front pipe, i dont know whats out there at the moment. apparently www.arrowdiff.com.au have dump pipes for about $300, CES racing have a good range apparently (probably abit pricier) and you've got the normal jap range for about $300 + freight...
The A/F ratio varies, deliberately. Mark kept it in the high 11's in the high RPM range because he said he was worried about detonation. He said he could have pushed it into the 12's, but with the last tweak he did there wasn't enough of a power gain to warrant increasing it further. I trusted his judgement on the matter :) But on the most part, until it hits around 100kph in 3rd gear (whatever RPM that is) it's low to mid 12's. Originally it was mostly high 11's and heading towards low 11's at the top end. I'll scan the dyno chart and upload it this weekend.
Cost was only for the tune, because I'd installed it myself a couple of weeks ago. That was $140, I don't know what he'd charge for installation.
The dump pipe he uses is built by him so it's fully custom. He talked about running an external wastegate as well, I think I might go with that, but it depends on how much extra it costs.
I don't actually know why the dump pipe is such a separate item from the front pipe, to me it looks like they should be the one and the same piece. I guess it must have something to do with the wastegate.
My car goes into Hills this Monday for the works:
Turbo
Boost Control
FMIC
ECU
Injectors
Custom Plenum & Throttle Body
Custom Fuel System
Front , Dump and Hi Flow Cat
I'll let y'all know how it goes - I'm trusting that i'll end up with a weapon - I've been waiting for 6 weeks for (a) Parts and Worksop availability and (B) When I can put the car in. I know it will be worth the wait - I'm just hoping I can show it all off at 2Rismo's Dyno day next weekend !!
BTW - Anyone who thinks that they are getting work done at Hills next week is mistaken - That week is reserved for me !!:) :) :):D :D :D :D
Originally posted by tlai909
640Nm sounds a bit hard to believe...
I'm thinking PowerFC + my AVC-R now.
T.
Have a look at my dyno readout. I was actually mistaken, the torque was 641 when power was at its peak, but the peak torque occurs earlier and is over 700 :)
Anyway this is why I asked the question about it being in 3rd gear rather than 4th.
Wouldn't that blow gearboxes?
640Nm is more than what a supercharged Jaguar does :eek:
Quite Frankly, thats because the dyno run was done in 3rd gear. If I did a dyno run in 2nd gear, I'd probably make 800Nm+
The gears/ratios act as torque mutiplier...
Turbo
Boost Control
FMIC
ECU
Injectors
Custom Fuel System
BTW - Anyone who thinks that they are getting work done at Hills next week is mistaken - That week is reserved for me !!:P:D:) :) :) :) :)
Hi there, what turbo is going in champ? and which ecu. also how much is the plenum and throttle body setting you back?
Cheers champ..
:uh-huh: :burnout: :shake:
  • 1 month later...
Any news after ur upgrades Brendan ?
Im wanting to get the front pipes of my car done and after not being able to find anyone decent in my area i think im gonna have to travel to Hills and wait 8mths to get it looked at.
Damnit i got the money now grr
Hey Guys,
Yep got most of the mods done, just the hi-flow cat and final tune to go.
Results so far:
Before : 150rwkw
After : 220 rwkw on low boost (14 PSI)
Tomorrow it goes back to get the cat and final dyno tune, now that everything is run in, we'll be able to do high (18 PSI) boost dyno runs/tunes.
Expecting 255-260rwkw prolly can get more, but poof goes the head gasket......
PS - 1 day after I got the car back (220 rwkw) I had to change the clutch cause she slipped when >4000rpm and loaded up. THe std clutch just can't take the HP.
I won't post the costs - but if you like the figures and have seen under my bonnet - (and you can wait for the work to be done) then go to Hills and tell Mark that you know about my car and I'm sure he will look after you - Yes, the wait was worth it.... And I have more to come........
Cheers,
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
