yeh looking forward to getting 200+ with no major mods
there isnt a whole lot left in the R33 turbo im afraid if your on the 14/15psi mark now with it.
1-2psi more and i think thats where the power increase will stop (if it isnt there already)... and where the wheel spitting will occur :P
Id say this is true. Last time i was on a dyno i tried 1 bar = 183rwkw and 1.1 bar = 185rwkw
Ok, just posting a brief update on my car.
Took it out for the cars and also my first quarter mile action at Heathcote.
Really really bad axle tramp and wheelspin. The car was shaking so hard the boost gauge rattled off the dash! LOL. Couldnt do better than 2.5 60 footers. My initial plan was to crack 13s and 110mph. But just missed out on both. Ran 14.2/3 every run and 108-109mph.
Popped my drag cherry and will attack calder asap.
Ah yes R&D on a RB20 to make big power is good. makes you use ur brain than just opening your wallet. will make the end result (if all works out lol) more rewarding.
When is this thing goign to be finished. If someone can get decent numbers out of an RB20 then i may bother sinkign a couple of hundered a month into my spare RB20, though i dont see my TD06-20G ever cracking 270-280rwkws no matter what head/cams mods i run:blink:
lol yes ROY this build has been going on for a while, but ive turned a car i used in a wedding into a drift machine and that takes money. so stay tuned. i was going to do the engine first but decided to start at the rear and work forward. once i start on the engine it will only take a few weeks and it will be back in and making some numbers. I can pretty much promise you it will crack 300rwkw. its just a matter of having the spare time and money.
Close to the 200rwkw mark. Got a tune the other day and got 255 rwhp @ 1bar. Was hoping for more like 290ish but will have to wait for new fuel pump to go in! hopefully next weekend.
Has HKS 2530
32 gtr cooler
550? injectors
z32
lumpyrom retune/remap
Had magor ping before tune and had troubles getting it to the stage where it wouldnt. Was told fuel pump should cure this so am putting in bosch 023. What sort of boost are others with a 2530 running? I was thinking of going to 1.1 bar but would like to see 300rwhp.
r32 rb20det (late model) swapped into USA s14 chassis
RIPS intake mani
tomei 260/8.8 cams
greddy cam gears (currently zeroed out)
gt30r turbo with .63ar turbine
550 supra injectors
fmic 24x3.5x6
hks exh mani and gate
retuned ecu for injectors and z32 maf with tweaked timing map
from the looks of it the lag is proly caused by the lean condition on spool up, once i get my biki rom from bad biki life should be much better.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
