hehe, yeah there is a place here stateside that will test oil for whats floating around in it......
yeah im using the emanage to fork with the maf signal (which it does do well) but since the ecu has an agressive timing map (actualy on the ecu) forking around with the maf voltage makes it feel terrible if i do it too much.
if i dont use the emanage to correct it runs too lean due to the timing map...... so its a catch 22 untill i can get the biki rom where i can see where i am on the maps.
there isnt that much correction on the map like +10 pts which isnt too terribly much but its enough to fork with the signal enough to really make it feel weird.
from what it looks like i might be able to get full boost at 4k assuming i can add fuel in the right spots (which i cant do with the emanage right now) and it should have a fairly beast/wide power curve if i can get it that way......
i will let you guys know my results tho for sure, because once the car spools its frightenly quick.
OK, so what you are doing is richening up the A/F ratios with the EManage, this retards the igntion timing and so it feels sluggish. Unusual situation, 99% of the time we are trying to lean out the A/F ratios by bending the AFM output voltage.
What I would do is increase the fuel pressure (adjustable FPR) so that I didn't need the EManage to make it richer. I would adjust the fuel pressure for 12 to 1 A/F ratio at the max power RPM. Then use the EManage to tune the other RPM load points. This will remove the need for large amounts of voltage bending by the EManage and retain some semblance of normal ignition timing.
If I couldn't get the injectors to flow enough at the higher fuel pressure to achieve the 12 to 1 A/F ratio , then chances are the injectors will be too small regardless of what ECU I am using. So upgrading the injectors is the next step.
Hope that was of some help
:blink: cheers :D
Hi Guys Ran my R32 gtst with a friends R32 both rb20dets just thought you'd like to see the results first time ive run at the drags in over 25 years and yes im on old fart but going fast never gets outa your system anywat clutch started slipping on the next runn so had to call it a night might have gotten better with a bit more practice
Cheers Peter
Hi Cubes
Power is 238kw and running rb25 box and the tyres are m/t et street drove there and back with them on
Yogi000
the turbo is still the prob at the moment runs out of flow by 6800rpm new turbo on order Gt3040r that will improve the top end hopefully
Cheers Peter
I cant read the time slip???
Time for some reading glasses mate!
Try this one, I touched it up a little
Great times BTW, one tough RB20!
Edited by Chris32
Damn...im running more mph but 6 tenths slower...lol i can t drive my car off the line for love or money:(
The answer is;
:P Cheers :D
Hi Guys
both cars are R32s both rb20dets mine's running the et streets the other was running Hooser semi slicks
Roy
I ran higher mph on street tyres but 1.5 second slower times
i think it might have something to do with tyre dia as the m/t's were 26x10.5x16 "si just fried the street tyres 1st ,2nd and 3rd
Cheers Peter
Edited by legend01
Hey legend would you mind posting up what modifications you've done to your car to get it to 238rwkw? And also your mates car if you know.... those are some awesome times. Very impressed with that 60ft time from a rwd.
Please run an 11 on a stock RB20:)
I cant recall reading if you are using the std gearbox? What clutch and diff is in the girl.
After the last track day in late October i want to hit the drags, my housemates poo RB25 thingie ran 0.1sec quicker then me, (but 3mph slower) cant have the quickest car in the house being an RB25:)
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
