pressumed wrong.......RB25
yes, but this IS an RB20 thread :P
Anyway, should have the money soon for a full microtech retune, dyno run and to fit bigger injectors.
Currently running 9psi on the RB20 with twin T28's, full boost at around 4.5k.
Going to up the boost to around 12psi, see what she does.
who cares if its an RB20 thread theres people putting there silvias and so forth in saying yeh ive got sum power in my SR or CA......so i decided to share, quite simply put, why descriminate engines and say its just an RB thread.
THIS is a RB20 thread!
If you want to talk about your *fast* 25 then start your own thread!
Mad RB20 In the works.
Super T70 Turbo
750cc Injectors
HKS drag cooler
Custom stainless exhaust manifold and dump pipe etc.
Dyno and 1/4 mile time to come... ;)
Hey looking forward to hearing about this ride.
Turbine
anyway, put my RB20DETT R31 2 door on the dyno, for a full tune and bumping up the boost.
Got 182rwkw @ 7000rpm on 13psi of boost in 5th gear. Dyno wasn't a dyno dynamics and this dyno was known to read lower than dyno dynamics dynos so meh.
Huh? 5th gear??? If so that would be some crazy power wouldnt it?
yea gears make no difference, the guy just decided to run it in 5th, guessing to maybe avoid wheel spin and get a clean run
as for responsiveness, it isn't great, but im used to it, and once it passes around 4000rpm, it pulls like a fkin steam train. Haven't really paid much attention to the boost gauge, just the tacho, seeing peak power is made so damn high up in the rev range, with a dead stock top and bottom end, so i couldn't really tell you when full boost is reached, suppose i could check tomorrow :rofl:
To be quite honest, im kinda dissapointed, i want MORE! :(
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
