Hi Guys latest update
New exhaust is on and retuned made a little more power but what its got now is how it stays thinks its past the limits of the standard plenum. Heres lastest dyno done this afternoon.
Edited by legend01
What cams are you running? Still running std valve springs? Turbo simply is out of puff/efficiency at that boost level?
Sky30's RB30DET is running around with a std RB20DET plenum and making 312rwkw @18-19psi, that has no issues apart from the stock log exhaust manifold being a restriction. Its running a big internal gate diesel .82 machined to suit a GT35R.
Id say on the rb30 with the length of the stroke it would have a lot more sucken and blowing power and the bigger pistons would help it along to, just my ideas on it though
cheers Peter
Hrmm.. Under boost motor doesn't suck. It does blow the turbo up but that doesn't have any affect on how the plenum performs.
I've seen this type of power curve occur with the old Sigma turbo's where the heads airflow capability is limited. Bigger cams, more lift and more overlap were required to keep the power creeping up as rpm increased.
I'm assuming your running a 3.5" exhaust and stiffer valve springs.
Is it possible the turbo's runing in to choke at 18psi for that airflow/power?
GT3076R tends to be pretty much 270 maybe 300rwkw with a well breathing motor.
I've seen 3040's push slightly over 300rwkw.
But still... 280rwkw rb20det. Damn impressive. :dry:
It is a GT3040r with 82 exhaust housings .But the part i like is it holds the 280 for near 2ooorpm then hits rev limmit b4 power drops of but im happy with that level of power just gotta try getting the smile of me face its begining to hurt
Edited by legend01
Aiming for about 2 weeks time bit busy at work and want to get the rear wheel alinment done since i took the hicas off be for i go to wsid pb there was 12.220 @ 111mph with the old setup so will be hopin for a bit better next time
well its nearly all done, just a few more bits, this is the engine that i hope to crack 300RWKW+ with. will it happen, u bet it will. its taken so long and its only a week or so away from dyno run in and full power tune.
anxiously waitin !!
i would not recommend those cam pulleys tho 30K Kms saw my teeth wear about 0.5mm. HKS have a new set where they use a harder material for the outer ring....
Great result. Yet another RB20 over 280rwkw!!!!!
What rpm is the 22psi reached?
Interesting curve. As mentioned its doubtful the plenum is the culprit, the Group A GTSRs ran with the standard plenum although its likely they had a bit of a porting throughout, or not?
What are the total exhaust mods? Maybe try a power run with it dropped just to rule it out?
Full boost by 6000rpm i think he said and the exhaust mod was a hks cat back exhaust 3.5inch .Not gonna worry about doing anything else for a while just gonna enjoy driving it for now . Rev cut is set to 7700 but it is a intresting curve as it keeps to 280kw right to rev limet havent seen that on another dyno run as yet and didnt wanna take it past that to see if it kept going, all in all quite happy with the result at the moment
Cheers Peter
Edited by legend01
Man, congrats on the results...that is awesome.
Cant wait to see a std engiend RB20 pull an 11. WIth far leses power then you i was able to get up around 115mph, but i suck off the line...you look good to get well into the 11s if you can maintain your previous 60ft time and combine it with some 118mph action :P
Awesome!
Yo everyone, just wondering if any of the RB20 owners with over 240rwkw have had engine failures or mechanical troubles when used in a circuit/drift enviroment? reason i ask is my rb20 just made 258rwkw @18psi (mods are listed here:) http://www.skylinesaustralia.com/forums/in...ic=103095&st=20 but the tuner recommended i only run with around 1 bar not because the tune wasnt safe, (it was detonation free at 18psi) but because the sheer mechanical strength of the motor could not take that sort of power continuously ie lots of revlimiter action in drift. Any opinions would be greatly appreciated, especially from roy & other RB20 heros who use there cars in circiut or drift where are they are given a pounding.
Cheers.
So many variables. I say take it easy, start at 14psi, and slowly wind it up looking constantly at the condition of the oil, water and oil temps etc. I have ran 234 at 18psi without probs at the track, but I tend to back off when water and oil temops get too high...about 4 mins of driving
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8th Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
    • Just yesterday the car started to shake a bit when idle. So tomorrow ima test the some wires and packs with the multimeter and see what it is. Hopefully is a pack because thats the easiest thing to buy same day here where I live in the USA.
    • shot myself in the leg and now last night I have shaking when I idle lol
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
