cubes
the thing is as stock as your gonna get besides from big turbo,injectors and ecu.
we've had the plenum completly off and the inlet ports have definatly not been touched, same goes for the exhaust side.
no obvious signs off it getting cams BUT we havent pulled the covers off to see, and definatly no cam gears because we replaced the timing belt
the TD-06 20g with 16c we think might be nearing its limits, id love to change the setup to a high mount gt30 .63 just for curiosity sakes but i dont want to start throwing cash at it id rather it went to my rb30/26...
its cheaper to retune it than it is to start changing things
He is running a T^D06-20G though with the 16am housing. I can see there being a few kws more in my setup. But i dougbt i could make more then 275rwkws. The bigger housing must really help the little 20G make more top. The 8cm housing im running is tiny :)
I wish i had the 8cm housing instead of the 10cm :(
DAMN L2 kit is going to be the death of me i tell you...
My cams should be here next week hopefully so will post up how things go once the car is running and tuned :)
I wish i had the 8cm housing instead of the 10cm :)
The 8cm housing certainly made mine a lot more responsive and nice to drive. I will contact you when i sell my setup, if you want to swap housings then it may suit me better as im more likely to sell the kit to an RB25 owner, in which case the 10cm housing is going to suit them better. Shame that more RB20 owners arent willing to turn to the darkside that is trust rather then BB Garret/HKS turbos as they tend to think they are bigger and laggier ;)
ive just made the purchase of a td06 with the 8cm housing. waiting for my manifold to show up then i can stick it all together and see what all the comotion is all about
Here is the latest result for my car...old result was 201rwkw at 17psi with a restrictive cat...now it has been replaced with a metal cat and it made 217rwkw at 19.5psi...Sam aka Dr Drift was able to dial in a few more degrees of ignition timing with the better flowing cat and hence the improved result...driveability has improved a fair bit with the added timing but its still abit of a slug down low (can't be helped as its an rb20)...regardless i'm pretty happy with the final result...i think its near the limit of the current setup but its still far off from the big numbers some of you are pulling...
1989 RB20DET R32
3" Turboback Exhaust with 3" Metalcat
Hybrid FMIC
Bosch 040
GTR Injectors
Z32 afm
Turbotech Bleeder
Aerospeed cam gears
HKS 2535
DR DRIFT Remap
Edited by limpus
What are the cam gears set at and what brand exhaust. Its strange but some of the cars making good power are usign HKS and Trust exhausts, whilst the cars that are perhaps a few kws down run Aussie or Z-Force etc exhausts. Perhaps it has to do with the quality of the mufflers and the fact that a 3" exhaust is 76.2mm where Jap 3" exhausts are 80mm?!?!?!?!?!
Cam gears are set a IN+3 and EX-6...as for the exhaust...its some generic jap exhaust that came with the car...but i had a large resonator welded in to reduce noise...so that can't be helping...
Edited by limpus
Any updates AD4M? Until Legend can get back out there you are carrying the 1/4mile torch. Have you cracked the 11 yet?
no updates yet Roy we're still in our off season at the plex, im counting down the weeks hoping it doesnt break befor then :cheers: only a month away now
Had a run at wsid 2 weeks ago first run though I broke the hicas lock . Couldnt figger out why the car felt like it had egg shaped tyres ,One wheel was flappen in the breeze steering itself,Was my first run in 18months so still gotta get some more practice in yet but still ran 12.5 looking for a better pb this wednesday hopefully .Second run I bogged it of the line only ran a 13.4,so still go some work to go b4 I get there, only had the 2 runs cause I found the hicas problem then so called it a night
Cheers Peter
hey all just in the middle of my rb20det build, once complete will have it dynoed and take it to the creek, just keen on getting some of your estimates on how much power i will have with,
to4e top mount
38mm external gate
z32 AFM
550cc injectors
bosch 040 fuel pump
plazmaman plenum
ems 8860
will be running her at 16psi any feed back will be great thanks
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
