Great work...
RB20DET swap (stock con rods, pistons/rings, cams)
-SDS stand alone engine management
-Turbosmart manual boost controller
-Custom intake manifold (Greddy type)
-Innovate Motorsport LM-1 wideband kit
-Garrett GTPR turbo, Hybrid by Tial, T04E Compressor:3'' inlet, 2'' outlet, A/R .60; Turbine: T3 inlet, 2.5'' outlet, A/R .63, T4 bearing journal core w/big T4 shaft
-OEM cast iron exhaust manifold w/wastegate bong added
-Tial 38mm wastegate
-Tial BOV
-Nismo low temp thermostat (165 degrees)
-custom copper 3 core rad
-Tomei metal headgasket 1.2MM thick 80.5MM bore
-ARP main gurtle bolts
-ARP con rod bolts
-ARP head bolts
-N1 oil pump
-HKS fine tune timing belt
-444cc injectors (oem GTR)
-Walbro 255L/hr fuel pump (with 3/8 line from back to front)
-Custom FMIC
-Q45 80mm throttle body
-B&M short shifter (Modded SR shifter)
-ACT HD street clutch 512 ft/lbs capacity
-Custom one piece drive shaft
-Nismo tranny mount
-Custom 3inch exhaust from front to back (no cat)
-Vibrant 3inch sleeper muffler
-VLSD (oem '91)
-Adjustable rear toe control arms
-Adjustable rear camber kit
-Adjustable rear traction rods
-Faze gauges, oil pressure and engine temp
-Mickey Thompson E/T Drag 26 X 8.5 X 15
-TIC brake line lock
How is it you are getting over 300kws with 444c injectors? Plenty of rail pressure? No denying the thing is running great times
I don't get it either, it's a complete mystery to me too, i'm running the stock rail and regulator, whats really gonna freak s*** out and when I say my stand alone is telling me I'm running 50% duty on these injectors at an A/F of 11.7 constant throughout the revs up to 8K, lmfao. They were sold to me as OEM R32 GTR injectors, they look it, yellow top feed Nissan inj.....
either way that's some top results dude
i think the only quicker rb20 i've heard of was a jap one in a gts4 that took out it's class in some drag battle over there
that was doing high 9s lol
aussies got to get our shit together and play catchup!
awesome work :happy:
Definitely not stockers then. :happy:
My 444cc injectors flow tested up as 480cc with 40psi base and 100% duty.
On the dyno they max'd out at ~250rwkw and required a 1point afr drop on idle (15:1 to 14:1) via the nismo adj fpr; it then grabbed 268rwkw on from memory 85% duty. The Z32 is swallowing ~4.75volts.
As the old rule goes.. 444cc is around 450 crank hp; 450hp is around 260rwkw (depending on dyno); mine were maxed with a 11.5:1 afr at 250rwkw and required more pressure; pump is a new bosch 044 mounted internal and larger 300zx/gtr filter.
Nothings iffy with it; on the same dyno my rb20det injectors were at 100% duty for a little over 180rwkw to hold a 12:1 afr.
Another blokes rb20det with std injectors managed 190rwkw but the afr's were creeping close to the 14's.
Sky30's old RB30DET at 312rwkw was at around 85% duty on his 550cc's, then there was rbmans rb30det which was around 230-240rwkw and was nearing 90% duty with gtr injectors also. All on the same dyno.
In saying that I suspect that a car that makes more torque requires more fuel for a given power level as it will tend to make its peak power at an earlier rpm.
If a motor makes the same peak power at 6000rpm vs one at 8000rpm from what I've seen the 6000rpm peak power requires a little more fuel.
AD4M, where does yours make its peak power?
FASTRB20 THAT IS AWESOME !!!
Have you got a dyno graph? What other plans have you got in mind for the beast?
Also what sort of compression are you running? With a 1.2mm gasket would it raise much?
Edited by jnr32r
afr's sit on mid to low 11s at first and the power dies off in the top end because it has alot of fuel dumped to keep the motor alive and topples below 10afrs.
I have a worthy RB20 to add to the list, but i would be cheating some, my donor chassis is a 2520lbs 240sx (2700 w/me in it) hehehehe, managed a 11.07 at 128.8mph, 1.521 '60 at low boost (22psi), and from experience, I'm well over 300kw at the rear wheels
the 11.07 run, 1.521 '60: http://videos.streetfire.net/video/19672bf...99e00b51eab.htm
an earlier run 11.48 at 114mph, 1.524 '60 : http://videos.streetfire.net/video/a8b026e...98e0175d428.htm
running slicks of course, 26 X 8.5 X R15
I'll be crancking the boost some this summer with a few more mods, looking to be in the deep 10's, how low i'm curious
Sylvain
Please excuse me, but I am a facts based realist and, as the guys on here know, I tell it like I see it.
No way it's got 300 rwkw with standard R32GTR injectors at standard fuel pressure, my experience tells me that there is no magic when it comes to engines.
Some further evidence;
The ET indicates ~220 rwkw
The TS indicates ~190 rwkw
The dicrepancy (220 versus 190) is due to the use of drag slicks on what is most likely a prepared track
Cheers
Gary
While I am in a realist mood, let's move on to this one.
The ambient temperature is 21 degrees and the inlet air temp is 33 degrees. That's a 12 degree correction factor, rule of thumb 8 degrees is worth around 5%, so the 405 rwhp is really 374 rwhp or 279 rwkw.
Cubes observation that "a car that makes more torque requires more fuel for a given power level as it will tend to make its peak power at an earlier rpm" is pretty close. Perhaps a better explanation would be that the maximum injector flow rate determines the maximum torque output. Since horsepower is simply torque X rpm, the higher rpm (lower torque) would allow slightly more horsepower with the same injector sizing.
Back to the car at hand, I have never seen a GTR make more than a genuine 265 rwkw with standard injectors. The extra 14 rwkw (265 versus 279) could be put down to the "Cubes" effect and/or the slightly lower drivetrain losses in AD4M's case.
As I said, no magic in engines.
Cheers
Gary
Well i know im about to max out my injectors at 260rwkws an i need to up my feul rail pressure, in which case i know several GTRs that are all making 300odd (ball park) on std injectors and have been doing do for 2 or so years. Still bigger injectors are the way to go when i can afford them.
Then i can wind the boost up to 24 psi and see if i can get a little more mumbo in the mid range.
Also SK, the TS indicates only 190rwkws? He ran 128mph! With 215rwkws i was only running 112mph. And re AD4M dyno figure. Its a dyno figure so whatever, i always thought it was normal that inlet temp is 10-20deg C higher then the ambient.
Also SK, the TS indicates only 190rwkws? He ran 128mph! With 215rwkws i was only running 112mph......
I'm with him, i've been around drag cars for a while now (dozen yrs or so), and seeing someone pulling off 130mph trap speeds with a 2720lbs car with only 254-295rwhp (190-220rwkw) is not realist to me...I'm curious to know where you dug up these numbers from Sydneykid, they make no sense....and yes I know that running stock GTR injectors and making this much power makes no sense either, I don't know more than you do on that note...
Edited by FastRB20
Thx , appreciate it :)
I have yet done dyno runs, the 1/4 runs were done on simple road tunning. Since i'm running the stock exhaust manifold I would like to see what improovement I would get using an aftermarket tubular manifold. For the compression ratio, since the stock headgasket is 0.9-1.0MM thick and smaller bore than the Tomei gasket, it drops the compression ratio down some, did not bother doing the maths to know exactly what it is but i'm guessing it ain't much.
Sylvain
Edited by FastRB20
It's in a lightweight 240SX, not an full weight R32GTST like yours. Take 200 kgs out and see how fast your's goes.
Why? Because some guys typically stick the DD temp probe behind the radiator to inflate the power figures. Was the dyno run done with the bonnet open? Usually, so the tuner can listen for detonation. So why the hell should the inlet air temp be higher than the ambient?
Cheers
Gary
Cheers
Gary
its still 2720 lbs,
meh!! after all this, finding out power output is an estimation, either mathematically found by the car's weight, trap speed & ET (which from my and a dozens other's calculations say that my engine develops in excess of 400rwhp) or from a dyno pull which I have not done yet, but still no method is precise, so there, we can speculate all we want, we will never know the truth of it...,
nismo make yellow 555cc gtr injectors
the simple answer is often the truth
This is interesting info....
Edited by FastRB20
Cheers
Gary
Im just going on the observation of the probe i used to have on the foam HKS air filter i had. It always ran about 15deg C (traffic, 10ddeg C higher on the highway) above what the air con was indicating for an ambient temp. That was with a shield, so with the bonnet up or down it wasnt making much difference to the temps, be it on the dyno or on the open road.
But interesting to note that the figure could be a few ponies optimistic....a 12 flat in a manual RB20 means more to me then any dyno figure anyway.
Im still in the midst of my rb20det build but checkout this guy whose selling a R32 GTS-T with a rb20det on ebay with what appears to be a stock bottom and top end with stock intake manifold and claims to have made 503hp at 14psi but has it at 3 right now.
http://cgi.ebay.com/ebaymotors/1993-nissan...1QQcmdZViewItem
what do you think, i think he just made a number and realized it was a time bomb and got scared. Damn nice interiour though.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
