I just got an EPA notice in the mail....
I have an Apexi Power FC
Boost controller
Pod
Exhaust
Im going to put my silencer back in the exhaust and the stock airbox, do i need to put the stock computer back in?
and how do i reconnect the standard boost solenoid? i realise that there are 3 pipes from the standard boost controller and with the bleed valve i am only using 2 2 of them with one blocked off.
So how do i reconnect it for the EPA test? does anyone have any pics of how it is done?
any help is much appreciated..
https://www.sau.com.au/forums/topic/58436-add-me-to-the-epa-list/
i dont think you have to reconect the standard boost controller, they dont care about your mods only about pollution control, just change your standard computer in and youll be fine, run as little boost as you can and youll pass easy, leave the rest its just a waste of time
it actually depends on the reason u have to go to the EPA...
if its just a noise test u will be ok but a screw in silencer wont pass as they measure without it (screw into the tip that is)
as inark said.... what type of EPA, is it just an exhaust compliance one by the sounds of it.
There is a grave mis-conception about an EPa notice lately. One is nothing more than a waste of 30 mins
Just make the exhaust quieter and go get it tested at an exhaust place licensed to test it.
Dont waste time taking boost controllers off and stuff as thats not what you were EPa'd for and an exhaust shop wont give a shit anyhow
The full inspection is the only time you have to take a fair amount of stuff off (which is unlikely unless a cop pulled you over and went to town on you one night or you've had numerous other EPA notices, which you have not)
This is a first offence but what worries me is that they gave me an appointment to go to the EPA testing centre in Mcleod... Hence why i am asking how to bring the car back to standard.
It is an Air and Noise test the notice states.
Inark: It is just a silencer in the rear muffler with the one srew to secure it, with it in the car is very quiet, so much so that i can bearly hear it so i believe i will be under 90db but i dont know about the legallity of the silencer itself. does it need to be tack welded into place?
I wanted to reconnect the standard boost solenoid just to be sure as it is only a 10 min job but i cant remember the correct way to do so. any ideas?
If the letter suggested you have to go to McLeod for the test, then its a full EPA compliance test.
Therefor, your only allowed ONE intake modification (ie: either a cooler, or pod filter...not both).
No boost controler, no fuel pressure ragulator, no injectors
Basically STOCK
Your silencer plate wont pass...even if you weld the plate in, its no accepted. I know this for fact
You will either have to put the stock exhaust back on (as its close to legal limit as it is) or somehow lower the current system down. Which you probably dont want to do as itll mean resonators/mufflers
Also, dont be sneaky and try to fool the guys up at Mcleod EPA. As they are pretty decentl blokes, they KNOW what to look for especially with Skylines as they get them in on a daily basis
Good Luck
i rang the EPA and was told they will be going over the whole car and as mentioned above, the silencer is illegal however can be welded at the screw but it need to be welded in a way that it cannot be just removed with the tap of a hammer. I suppose it all depends on the tester on the day.
therefore ill leave the front mount and the exhaust but ill have to remove the computer and the boost controller..
Any idea on how to reconnect the standard solenoid?
i had to remove my avcr as well when i got mine tested. I got the boost solenoid removed completely as well as removing the screen. My powerfc was replaced with a stock ecu. They plugged into the diagnostic port to test something and it wouldnt work...so they assumed aftermarket computer. The opened the panel and saw the standard ecu. hehe
[WLDCRD]: if i put the stock ecu in the car and then replace it with the Power FC, does the PFC retain the settings i have or will i have to dyno the car again an tune it again?
from whjat people say, they really know what they are talking about at the EPA testing centre.
anyone have any pics of the stock boost solenoid so i can plug the hoses back up? There are 3 hoses from the standard solenoid, and at the moment with the bleed valve one is blocked, will i have to reconnect it?
']They plugged into the diagnostic port to test something and it wouldnt work...so they assumed aftermarket computer. The opened the panel and saw the standard ecu. hehe
i don't think that they can 'plug something into the diagnostic port' - would they be liable if they fried something? I doubt this is within their 'power'
i certainly wouldn't be letting them do anthing of the sort!
silvar33: powerfc retains all the settings
Ronin 09: yeah they did check it...they go throught near the steering column. They have the plugs! I dont think they alter anything...they just checked.
haha.. I've been shown how to remove and re-fit the AVC-R boost solenoid 3 times and I always forget which hoses go where! Next time someone shows me I think I should be taking notes :rofl:
Thats too bad. To avoid a return trip to EPA and get it sorted in one day you need to do the following;
Apexi PFC - remove, pop in stock ECU.
Boost controller - remove. not allowed because it can change the emissions, even if on stock boost levels
Pod - You are allowed a pod or a FMIC. one or the other not both.
Exhaust - When i go to EPA i have to put on a stock exhaust, my stock Exhaust measured 88dB (stock cat,muffler etc). I've been to EPA and seen guys with exhausts with a baffle plate, they will fail you for 2dB over so save yourself the trouble, get a stock exhaust (can be purchased for $100 roughly, check forums, good investment) and get it bolted on (about $70 from exhaust joint) , or if you want you can do it yourself with a trolley jack...who can be bothered i just pay the $70 and get it done in 30 mins without getting my hands dirty and back/neck sore!
Good luck with it.
']JAPCAB: you can have both pods and front mount if you got a GTR as the fmic is standard and you are allowed one induction mod :)
Not if the intercooler is aftermarket. Standard intercooler and aftermarket pod filters are ok. You can only have aftermarket air filter OR aftermarket intercooler - not both. Personally I think this rule is BULLSHIT, I've got my stock R34 airbox handy just in case I need to swap it over. Although last time I went through a RWC check point they didnt say anything about the 2 induction mods. Maybe cos I'm not on my P's :P
thanks guys...
ill have the car standard apart from the front mount and the exhuast, however i am going to pay the $30 ish for a db test and if it passes ill weld the silencer on as the EPA said this was fine to do so. if it fails ill buy a stock muffler and have them install that.
My only concern in how to reconnect the stock boost solenoid... there are 2 hoses... which 2 are connected together by the T-piece and which one connects to the solenoid on its own? am i right in saying that the hose from the turbo connects to the top of the solenoid and the other 2 hoses are connected together via the T-piece and then to the bottom plug of the solenoid?
I am really desperate for this info as i would assume if it is not connected together it would not meet emissions?
Also, how strict are the emissions? would an R33 GTST with only front mount and full exhaust pass easily?
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
