Power FC is in which I bought second hand, and just running of the base map... The guy I bought it of, had already done the start up procedures, so pretty much just took out the old ecu, and replaced it with the Power FC...
Everything runs fine, however this light comes on and stays on... What does it mean and is it a good or bad thing???
I am going to get my car dyno'd but not till Janaury (Christmas presents are expensive!)
So can anyone identify my light problem?
https://www.sau.com.au/forums/topic/58474-what-does-this-light-mean/
umm, that is not good. That's the check engine light, which usually means you have no oil pressure or something has gone drastically wrong with your engine. In your case however, with a PFC fitted, the PFC uses the check engine light to tell you that your engine is detonating. Sometime the value at which the PFC will display the warning is set very low, this could be your problem, either way, check it out.
Richard
Richard
So using the hand controller, how do I go and change the setting so the light is not on??? ie moving the warning up? And what should it roughly be set at?
It was fine when I had the stock ecu in, there was no light thingy.... Should I be driving round the next month or so like this????
If its running of the base map, it shouldnt be detonatin right??? I mean, I took it for a spin, everything seemed alright, ie engine temp, boost stayed constant @ 7psi still
Its a base map tuned for japanese ignition timing on japanese fuel. I wouldnt go around flogging it too much, but I am sure other people will disagree with me.
Does the light flash? The Power FC warning lights flash a sequence of codes, not stay on solid. Check and make sure that the boost controller option is turned off on the power fc. While the car usually doesnt start if this is on (and you dont have the PFC boost controller), I have heard of some starting and just showing the warning light.
At the moment running optimax on the car.... The light does not flash, it just stays on constantly.... So even though its on, and Im running off a base map, is it still stable to drive??? Everything seems fine when i drive it
Im guessing it would be stable to drive over the next week or so... I think ill get my dyno done earlier now...
If it's on and stays on, regardless of how you drive, chances are you still have the boost controller function turned on in the PFC, and don't actually have the boost control unit.
Ok, ill go check that out now.... Did anyone else ever have this problem??
  • 3 months later...
Those are the reverse EL dials.... I bought them from a Group Buy off here last year sometime...
Anyhow, the dials are gone now, and im back to the standard dash, but have red LED lights in it, which makes the numbers light up all red at night. Matches the amber defi's :P
this ones easy, your running a pfc with no apexi boost controller right?
if u check yr settings you'll prolly find the boost control is set to on.
THanks, yeah that was the problem... Had the problem ages ago when i just tested the PFC in the car... But now its all tuned, and making some healthy figures... ;)
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
