AFM to be destroyed!!
You'll have to be quick as I'm about to destroy it with the biggest bloody hammer I can find. hmmm.
This 20 pound sledge should do the trick.
Vote now. Should I destroy this remarkable piece of Nissan engineering?
Good Points: It is a Nissan product, it is off an RB20 - the sickest of all the engines, it serviced me well for 2 whole years, it didn't break down on me even when it was completely stuffed.
Bad points: I GOT BEATEN BY A FRIGGIN 2.0 N/A CALIBRA!!!
I will post photos soon and the Queensland SAU community will decide its fate.
https://www.sau.com.au/forums/topic/58761-afa-vote-now/
OH OH OH Can I buy it off you?!?! I just want the housing not the actual afm bit, just the plastic bit, if it fits rb25?
Other than that, the hammer is the only solution, but video it and post it up for all to share!!!!!
https://www.sau.com.au/forums/topic/58761-afa-vote-now/#findComment-1125686
Fire.
Its the only way.
..... Unless said fire is coupled with large explosion? I suggest putting 2 soda bulbs inside the afm, filling the rest of the space with the shit off sparklers, then wrapping the lot in alfoil. Insert a sparkler for a fuse, ignite, run to safe distance and film.
Cheers.
https://www.sau.com.au/forums/topic/58761-afa-vote-now/#findComment-1125968
Ok... this is the answer....
Bring it along to the next MSC so we can play a quick game of cricket with it as the ball (have to chuch it full toss, as they dont bounch well) but yeah... Then after a bit will can burn it... Then put it out then put a fire cracker in it.... Then burn it some more.... Then kick it round some in a game of soccer as it will be a molten ball by now.... Then we can burn it again.... Then maby, maby burn it one more time.....
Hows that???
https://www.sau.com.au/forums/topic/58761-afa-vote-now/#findComment-1131298
