Hey all...
trying to sell my R32 Gtst.... but for good reasons..
Upgrading to a GTR...
But i wanna get as much for it as i can.. Obviously
Interior:
Neons
Autometer boost guage
Sports wheel and knob
Cd player
Alpine splits
Snap On seat covers :)
The rest im taking out
Exterior:
Blue with purple pearl paint job
Full 1 of a kind bodykit
Stock rims
Full underbody neons
Mods:
3" custom exhaust from turbo back to cannon muffler
K&N pod filter
High flow turbo
Turbo smart dual stage Boost controller.... Nah taking with me!
Pretty much stock... Just looks nice :P
So what do we all recon i can get for it???
Opinions are GREATLY appreciated....
THANX ALL!!!
C U SUNDAY!
https://www.sau.com.au/forums/topic/58827-wats-my-r32-gtst-worth/
Only my opinion Andrew without looking - In the vicinity of - $$$...PM sent - based on my recent sale of previous Sinista (also a GTS-T Worked).
Suggest - Plse dont post price on forum. Set's expectations.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
