well my GTR finally comes to my house tomorrow..
What should I do to it before i start it up etc?
I have heard that I should flush the oil and stuff..
Im going to go buy some stuff for it after it comes..
irridium plugs???
motul turbo lite 3000??
coolant..
is that all i should get? will those plugs and oil be alright?
its an 89 r32 gtr...
thanks
https://www.sau.com.au/forums/topic/59078-i-get-my-gtr-tomorrow/
  • Replies 43
Wow, where to start...
this thread of links in the maintenance forum would be a good first call. http://www.skylinesaustralia.com/forums/sh...ead.php?t=35442
A biggie that you may overlook in your haste to get "going" is to make sure there will be no problem stopping!!
i.e. CHECK BRAKE PADS and FLUSH BRAKE FLUID and bleed brakes.
Hope you have the finances to afford to run a GTR as well as buy it....
CUT AS!
i took the day off work so i could be here for when my car came.. and it didnt even come!
i called and apparently its coming tommorow morning now.
i went shopping tho.. bought some turbolight 4100 oil, set of iridium plugs, coolant, injector cleaner, radiator fluch, engine clean and an oil filter :(
congrats anyhow..
just make sure it does *have* oil, has coolant, has brake fluid - then its more than likely you're not going to kill yourself or the car.
I still haven't done all the servicing for mine as it had the above. I figured if it was sitting there for 3-4 months going nowehere, another month of not being serviced going not going anywhere wouldn't matter. Its not like I can drive it anywhere at the moment anyhow.
I was just happy because I fiddled with everything, and everything *worked* (except the aircon... think gas). It's always those minor little things that don't work properly that give you the shits and can be hard to diagnose. That was the best part, knowing that it wasn't an obvious lemon :(
lol...
its ***in awesome man..
so so so clean..
i think somebody unplugged the afm so that nobody could flog it before it got to me.. cuz i thouught mine was broken cuz it wouldnt hit boost.. its all good now...
i think i should have bought a battery the other day :P
had to keep starting it with a charger.. .
it came full of fresh oil, the paint is perfect, sounds great up to 4500rpm.. (thats all i took it too)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
