If anyone has any suggestions of locations, please post them up. Here's some ideas as to what I'm looking for:
* Quiet - can't have people walking through shots or traffic on the road.
* Scenic - either a nice backdrop to put the cars against for static shots, or something that can blur up nicely in motion (trees, buildings etc.)
* Smooth/flat surface - self explanatory really.
* Accessible - Somewhere within reasonable distance from the city.
  • Replies 111
theres always that place we go on the GOR trips... very scenic and u can take pics from the hill to get a LOT of cars in... its flat and huge. i'll post pics of the spot im talking about when i get home tonight.
Locations:
Tally Ho Business Park - Burwood. Has lots of places to take some good shots. Industrial Buildings - Hi-Tech Buildings - Scenic Lake Backdrop - Smooth Surface - Heaps of space and different locations.
Graff Wall - There is a great graff piece on Ferntreegully Rd. that would make a nice backdrop if your into that sort of thing.
Cop Station @ night - Bit of Fun... "DEFECTED DECEMBER"
New Quay - Docklands
Telstra Dome @ night - heaps of room and not much action around the stadium itself + looks GRAND & Bright with NEON + some of the buildings around it are "interesting"
Performance Shop - ?????????
Just some initail ideas
Preliminary Shoot
Date/Time: Sunday 26th December, 6pm
Who should attend: Anyone on the list who is available on the day (and wants to drive to Greensborough)
Shoot details: This is really the "pilot" shoot, so if you miss it don't worry. We'll be discussing a few locations, testing some angles, working out any problems we might face.
YES, there will be many more shoots!
There's a place around Albert Park Lake which I like taking car shots... nice when the sun is going down.... great back drop with the palm trees and lake. I'll try take a few new shots of my car later today.... If the sun comes out
Preliminary Shoot
Location: Tally Ho Business Park (let's give this a shot), Burwood. Not sure of the address, but it'll be somewhere.
Who should attend: Anyone on the list who is available on the day.
ALSO an awesome one at night is in the city near the southbank mitsubishi yard theres this big red funky shaped building with lights on it,.... very arty and ive always wanted to do one there but keep forgetting :D plus it has a nice big paved area out the front
Preliminary Shoot
Location is on corner of Springvale Rd. and Burwood Hwy. Enter off Springvale Rd. going Nth. @ MYOB Building or enter off Burwood Hwy. @ Lakeside Drive (where VIC Roads is)
I wold say that the MYOB car park is the best meeting spot (out in the open)
Someone may want to drop in and scope the place out if passing by in the next few days.
Please don't blame me if the location is not ideal... but we will have many other shots and locations to visit B4 final compilation is made.
If you guys want a 32 gts-t in the shoot id be more than happy!
My car apprears to be quite clean:
It recently had a re-spray (white) its got 18's, gtr front, no rear spoiler, lowered with tein coil overs and blitz front mount.
Interior is spotless...
take it easy
Mark
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
