I have the R32 GTR Manual, R32 GTST manual and the R33 GTR+GTST Manual.
These include all engines of the following:
CA18i
RB20E
RB20DE
RB20DET
RB25DE
RB26DETT (R32)
RB25DE (R33)
RB25DET (R33)
RB26DETT (R33)
Includes all info for 4wd systems and electrical and chassis information. They are all in English and I will be setting up a FTP server to host them.
Please let me know if you are interested and what connection your internet is so I have a fair idea how far to break it down.
I will be willing to post them but at your own expense. I have them all included in a drop down autorun menu ready to go.
https://www.sau.com.au/forums/topic/59368-r32r33-gtrgtst-manuals-in-english/
also, if that one is not working. I will be starting a different server at 6pm tomorrow 23/12/04. If anyone is still downloading from the original at that time, you will be kicked.
You can log on to ftp://[email protected]:77
Sorry, edited that one back. I did the transition just now.
Just use this one, it should be faster as I have direct cable and this server will utilize it. Should be faster for those of you with adsl and cable.
I've placed a mirror on my server... but if it gets raped, I'll remove it..
i'm only 60kps upstream.. so be good!
http://skeleton.net.nz/~oiad/manual/R32 - GTR Manual.rar (20.8MB)
http://skeleton.net.nz/~oiad/manual/R32 - GTST Manual.rar (22.5MB)
http://skeleton.net.nz/~oiad/manual/R33 - GTST+GTR Manual.pdf://http://skeleton.net.nz/~oiad/manual...+GTR Manual.pdf (149 MB)
You may want to use a download resumer or something.. the server is pretty stable, but I see a few people starting, then stopping..
THE NEW SERVERS ARE AS FOLLOWS. (MY IP CHANGES WHEN I REBOOT)
IP: 60.226.67.88 USERNAME: SKYLINE PORTS: 21,77 OR 99
well i managed to get ftp://60.226.67.88:77 but it prompts for a username i have put in
Username: SKYLINE password: blank
Username: SKYLINE password: SKYLINE
Username: skyline password: blank
Username skyline password: skyline
also log on anonymously
no goer ???
salival Thanks for the link. I successfully downloaded the file but can't open it. I don't know much about computers. It says windows needs to know the program that created it. What should I type in?
download winrar and install that. www.win-rar.com
once you have extracted the PDF, you'll also need Adobe Acrobat Viewer. www.adobe.com both are a free download
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
