  • Replies 416
Posted Images
  • 1 month later...
I got a level 48 human warrior with plenty of epic equipment on Kil'Jaeden but havent played for a very long time.
My little bro just sold his account with 3 level 60s on eBay for nearly $500
WoW rocks full stop
I'm a lvl 13 (undead mage) n00b atm on Blackrock so if someone wants to help me out (Currently doing pine forrest quest's) Then gimme a PM.
Just need some help doing some quest's
Tell me when you're in STV, i'll...help...you out.....
STV? Sorry i'm a noob lol
I'm at crossroads atm, been told to head there to lvl quicker.
He's NE ( night elf ) you're undead.. he's going to.. kill you lol
He can't help you out anyway what so ever heh :P
You should have rolled on frostmourne.. aussie server or barthilas, new aussie server..
I plan to return to Frostmourne after my exams are over, ( 60 lock )
STV is a lv 39+ area just south of duskwood.... its a major ganking area, me friend loves to go around there and gank hordes..... I have a lv hrmm.. 20? undead mage on blackrock as well, but been ganked to death around ashenvale by lv 50+ gives me the shits and I ended up just sticking with proudmoore...
Anyone on proudmoore?
  • 1 month later...
I've got my rogue on Lightbringer, never really had time for alts...
She's got 8/8 nightslayer and 5/8 bloodfang atm, we've been working on nefarian for 3 weeks (HES NO PICNIC!!)
Here's us enjoying the lab packs in BWL....
WTF Winter...
Tis Arduous/Scarletdeath/Ladyinred/Jelinda
hi.
Anywho, i xferred off that Lightbringer Rock. I'm on Khaz'Goroth now, with my 60 Warrior Arduous (i still have my 60 mage and rogue as well).
Raiding Naxx now, AQ40 is done (C'thun is such a fun fight - any guild that skips it is only hurting themselves).
Guild is called Eternity, we're not the top on the server, but we're in the process of restructuring to catch Time and these new upstarts ReBorn (who seems to go through members like i do tires....).
  • 1 month later...
Lvl 60 Paladin on Tichondrius - Clerion
Lvl 60 Mage on Frostmourne - Frozenova
Guild cleared ZG/AQ20 - Cleared MC and BWL - Up to Twin Emps in AQ40. Currently 80% of guild attuned for Naxx :laugh:
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
