  • Replies 40
Bought myself a sub, amp and rear speakers to go with the fronts and head unit i bought 6 months ago lol... the rear speakers in there were factory, and had seen better, less broken days lol... Santa left me $300 to mend the hole in my pocket and some other goodies... got a shirt off my gf, and my brother installed my stereo!
Pretty good chrissy really.... doof doof doof doof hehehe
Hehe, there is my list, from mine and my g/f's family:
- Car wash set - shampoo, sponge, all the chemicals.
- Car polish buffer x 2 :))
- Car polish
- Pneumatic jack + stands + wheel chops
- Steam cleaner for my wheels
- Chocolates
Spent 5 hours cleaning and polishing the car on sunday, rained the next day, stormed today, ended up having the whole car covered in salt :)( Washed it again today... shiny :))))
Remember its ok to cheat a little to impress ppl:) Keep a bit of that strong home mix bourbon in your mouth when you test yourself. Sure to get an impressive reading:)
Heh heh- I like how you think Roy!
Seriously though, it's a pretty good pressie- the jolly fat man got it right this year.
We were at my mates place and his g/f brought a proper brethalyzer from work. I did a mouthful of bourbon and blew 0.670. After that the machine said:
WARNING!!! YOUR ALCOHOL LEVEL IS DANGEROUSLY HIGH!!! YOU HAVE EXCEEDED THE MEASURING CAPACITY OF THIS MACHINE!!!
And then:
RECOVERING FROM THE LAST SAMPLE!
Which it sat on for about 5 minutes. Normally its like half a minute... Hehehe, good fun.
Another thing we did was joined up about hmmm 20 or so straws and blow through that. We were all blue :)
All I got for christmas was my 2 front teeth... SERIOUSLY!
They got broken playing ice hockey a few years ago and was not happy with the work that I had done.. Now I am getting Davinci vaneers and laser whitening! Yipee..
Got some sunnies from the missus too!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
