Its on Friday, and I think Jayce said he needs definate numbers this afternoon to book with so make your mind up boy!!
OK i will not be able to make dinner!!! as my flight gets back in however i will probably come out and say hi to yall :D
what are you all doing after the dinner at the restraunt ???
  • Replies 73
I am so boonerfied I just bought a VL COMMY :D
............. so sad.......
I will replace the holden badge with a nissan one....
Wish I could bring the GTR out as it looks a fair bit better now, but I have not yet finished the snail instal.
Jayce Like i told you lastnight in braddon that i will be coming after work for a bit finish work around 8 so will pop in and say hello to every one and check out the tits and cars that will be wandering around the street.
if we didn't just spend 22,000 on new furniture for the new house we would come down and occupy a table, but the DIRTbank is feelin' the pinch.
DIRTbank- :bahaha: Seriously-22K on furiture?!That's,like...2/3rds of an OS Giken 3L kit(hint hint)
Alright:all done!To answer Nik's question-yep,outdoor seating.
Final numbers are as follows:
*John(JB)
*Stu
*Kyl
Richard(Sinista) + friend
Andrew(VeilsideR33)-but running a bit late...
Nik(Amaru)
Ewan(Aurora)
Gus(R31_Silo2)
Mark(the drunk)
*Fitzy
*Michael
*Terry(window tinter to the stars) and Brooke
*Jo and Michael
Stirlo
Wayne(Rumble)-welcome on board! + 1
Al(SAU Vic vice prez') + 1
Final numbers: 21
With possible guest cameo's by Leech,GTS_duy and race_snooze...
I'll endevour to get there a bit early to make sure things run smooth-official time to "move into staging and watch the lights" is 7 pm.Those of you that plan on giving the bottle(or whatever) a large nudge that night,remember to cash someone up BEFORE memory loss sets in(preferably me-as I'll be the one stuck with working out the bill...).The newbies that don't know me,just look for a black and grey Nismo pitshirt(Damn you,Andrew!Now look at what you've done!I'm already planning what to wear...Then again,is it any suprise that I'm wearing somethin Nissan?!)-righto,everyone:see you there!
Hi Allan,
Just SMS'ing mine and Jayce's number Now.
Richard:cheers:
Can someone please sms their mobile number and name to my phone, so that i can contact you, should i have trouble locating the place, etc. Thanks.
My mobile: 0427 076490
c ya there!
Alan
:D
c ya there!
Alan
:D
Sounds like Richard already has got my number to you(Thanks,R. - I'm a bit slow this morning...!).Look forward to catching you all there! My mobi' for anyone needing directions or whatever:Jayce, 0414 484 171.
For whatever 'ey Jayce? :D
Well,y'know...gotta keep ya options open! I also offer counselling,parts exchange,boy-to-girl chatline,perscriptions filled...a plethora of services,actually! :bahaha:
Hey Guys,
I am heading over, and would like to catch you guys after dinner if I can, not that I don't eat - but I'll only get to Canberra around 9. Are you guys going to be cruising around or be anywhere I can find?
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
