Its on Friday, and I think Jayce said he needs definate numbers this afternoon to book with so make your mind up boy!!
OK i will not be able to make dinner!!! as my flight gets back in however i will probably come out and say hi to yall :D
what are you all doing after the dinner at the restraunt ???
  • Replies 73
I am so boonerfied I just bought a VL COMMY :D
............. so sad.......
I will replace the holden badge with a nissan one....
Wish I could bring the GTR out as it looks a fair bit better now, but I have not yet finished the snail instal.
Jayce Like i told you lastnight in braddon that i will be coming after work for a bit finish work around 8 so will pop in and say hello to every one and check out the tits and cars that will be wandering around the street.
if we didn't just spend 22,000 on new furniture for the new house we would come down and occupy a table, but the DIRTbank is feelin' the pinch.
DIRTbank- :bahaha: Seriously-22K on furiture?!That's,like...2/3rds of an OS Giken 3L kit(hint hint)
Alright:all done!To answer Nik's question-yep,outdoor seating.
Final numbers are as follows:
*John(JB)
*Stu
*Kyl
Richard(Sinista) + friend
Andrew(VeilsideR33)-but running a bit late...
Nik(Amaru)
Ewan(Aurora)
Gus(R31_Silo2)
Mark(the drunk)
*Fitzy
*Michael
*Terry(window tinter to the stars) and Brooke
*Jo and Michael
Stirlo
Wayne(Rumble)-welcome on board! + 1
Al(SAU Vic vice prez') + 1
Final numbers: 21
With possible guest cameo's by Leech,GTS_duy and race_snooze...
I'll endevour to get there a bit early to make sure things run smooth-official time to "move into staging and watch the lights" is 7 pm.Those of you that plan on giving the bottle(or whatever) a large nudge that night,remember to cash someone up BEFORE memory loss sets in(preferably me-as I'll be the one stuck with working out the bill...).The newbies that don't know me,just look for a black and grey Nismo pitshirt(Damn you,Andrew!Now look at what you've done!I'm already planning what to wear...Then again,is it any suprise that I'm wearing somethin Nissan?!)-righto,everyone:see you there!
Hi Allan,
Just SMS'ing mine and Jayce's number Now.
Richard:cheers:
Can someone please sms their mobile number and name to my phone, so that i can contact you, should i have trouble locating the place, etc. Thanks.
My mobile: 0427 076490
c ya there!
Alan
:D
c ya there!
Alan
:D
Sounds like Richard already has got my number to you(Thanks,R. - I'm a bit slow this morning...!).Look forward to catching you all there! My mobi' for anyone needing directions or whatever:Jayce, 0414 484 171.
For whatever 'ey Jayce? :D
Well,y'know...gotta keep ya options open! I also offer counselling,parts exchange,boy-to-girl chatline,perscriptions filled...a plethora of services,actually! :bahaha:
Hey Guys,
I am heading over, and would like to catch you guys after dinner if I can, not that I don't eat - but I'll only get to Canberra around 9. Are you guys going to be cruising around or be anywhere I can find?
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
