yeah i got a hcr32 stock cept for exhaust and filter, and atm has a greddy adjustable bov, anyway due to stupidity on my part ive threaded the screw at the top u use to adjust it and as such cannot close it enough and rendered the thing useless, ive accepted the fact ima need a new bov but i dont know what to get, i didnt purchase this one and all i know is i want one that makes the whistle noise, not the flutter or tssshhhh.
atm im running 11 psi.
this is a pic of my current bov
http://www.roadraceengineering.com/parts/g...dy-stypebov.JPG
https://www.sau.com.au/forums/topic/60081-need-bov-help-~~/
HKS SSQV make a high pitch sounds their good valve's,
You can get all sorts turbosmart type II, Blitz BOV's
Depends what you want or you can have no bov and have it plumbing back through the turbo which makes a flutter sound but its no good for you'r turbo after a while. (so i've herd)
:D
Jun
https://www.sau.com.au/forums/topic/60081-need-bov-help-~~/#findComment-1143090
Stock Plumback. Can get one for under $100 and is perfect
Not having a BOV will shorten the life of the turbo. I hear people doing stupid things to get the flutter such as blocking the plumb back pipe. Dont think causing a noise is more important than the life of the turbo.
This flutter noise you talk about is a Compressor Surge and is not good for the car...
https://www.sau.com.au/forums/topic/60081-need-bov-help-~~/#findComment-1143506
okok explain this to me, my current bov which i ****ed up, the greddy adjustable one, basically if i open it i get the tssh noise with a slight whistle on full boost and a slight flutter under fullboost ie 2500 shift, however if i close the bov fully it would make the full flutter sound which sounds cool and all but as u say is compressor surge and is assing up my turbo ?
okok now atm ive ****ed the bov by threading the adjuster completely and atm its just screwed in enough to stop air from flowing through there and thats about it, infact its so loose im scared it might come out, and in this form it just makes a big long tssshhh noise and thats that, im assuming im losing boost with it set like this but yeah have no choice, but i cant afford bov right now, is this wrecking it ?
and isnt a plumback bov essentially my bov closed ? hence causing the flutter and damaging stuff ?
https://www.sau.com.au/forums/topic/60081-need-bov-help-~~/#findComment-1145515
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
