  • Replies 102
thank god i dont have all that ABS crap looks so messy.
thats mine a couple months ago
soon to be filled with big power RB26 and lots of polished and CF bits to go in as well.
It seems your R32 is the banks best friend lol, its nice though, is that picture of that interior in your sig your R32? if so very,very nice.
muahahahaha yeah ours too!
an awful lot of bits come out of the inside when you start pulling them apart :D
Haha, i reckon, unforunately i only realised after i started pulling it apart.
Some nice paint there.
ylwgtr2 & cameron, Can you give an idea how much it is to do detailing like that on the engine bay?
OwWww. some shiny engine there. ;) I hate to be keeping those clean.
Taking off the cam cover is a bit of a worry. I'm worry something get jammed between the two gear and cause some damage.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
