  • Replies 84
Fatz you do have a couple of options here , first is to replace the .50 ARR comp cover with the larger .70 ARR T04E cover and keep the backplate .
Second is to use the larger series T04S cover and backplate (adapter ring) which is what Garrett did with their GT3540R turbocharger .
If your finances are limited go the larger ARR .70 "E" cover . If the sky is your limit go the "S" bits . Also remember that the T04S covers are quite large so make sure there's enough real estate where your turbo lives .
Generally compressor covers are sized around airflow rates or speed . So for a given compressor wheel the larger the Area Radius Ratio the lower the gas speed will be and vice versa . Also the larger it is the less chance it will have of being a choke point at high wheel speeds . Someone did tell me that all else being equal going up in comp cover AR brings the boost on a little later and "hits" harder .
With most Garrett turbos there is a set compressor wheel diameter for each wheel/cover family , ie 60mm wheels T3 covers , 71mm wheels T04B covers , 76mm wheels T04E covers , 82mm wheels T04S covers .
In recent years Garrett started going up a size in cover with some of the GT BB series compressors . I think this is because the comp wheels are mechanically stronger , and and can still pump efficiently at much higher rpm's than the bush bearing has beens . This is a win win situation , the small high speed wheels are compact , cheap to produce and more importantly have less innertia so spool sooner .
Examples of this are the little GT28RS (T04B comp cover) and some of the GT2835R series turbos with 71mm compressors and T04E covers .
The Garrett people inthe US tell me that the up sized cover , and a little extra tip height on the wheel , gives extra pumping capacity and a few more points compressor efficiency .
I can only think of two examples of Garrett turbos that went smaller in cover size , they are the HKS GT2540 and the Ford GT3540R . The 2540 is getting on and was probably an attempt to get a bit more flow and power out of a small series turbo , and a low mount compact (convienent) fit for GTR's .
Its safe to say Ford was not looking for serious performance with the XR6T so a compact and probably cheaper adequate cover got the nod . You can bet they knew people would modify them for performance , so the limited cover capacity may have been intended to limit the performance with the std turbo but not affect the standard state of tune .
Cheers A .
yea just stuck a side pipe on the beast and took it out to the drift day
sadly budget has died in the arse so i will have to putt around for some time until a set of cam gears arrive and the powerfc which is probably about 3 months away
im quite happy with the power but as soon as those cam gears are in hopefull it will bring it on a bit better
if cam gears dont bring it down to 4000rpm with power fc and a decent tune then i will consider the upgrade to external wastegate and a .86 rear housing and combine it with the larger front cover
but hey im happy as a pig in shit at the moment and when i win lotto ill do the next big upgrade
ive also got a rb30 complete engine that will be getting a solid bottom end over the next few years to replace the gtr bottom end when or if it ever goes
yea baby
anyone have some cheap cam gears
pete
  • 5 weeks later...
  • 2 months later...
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
