sorry guys this could be a silly question but i recently (about a month ago) bought an R32 GTR 94 model stock as a rock and loving it and 2 weeks after i got it, it was given a major service inluding , timing belt, oil, oil filter, fluids. diff oils, transfer case oils, everything and anything that could be replaced pretty much was.
so any way i havent really been booting it as i am trying to adjust to the more of a race car feel then the luxury comfort feel (that my previous R33 GTST offered).
But Yesterday i gave it a fair bit of stick here and there and parked for about 15 minutes then had a 20 minute drive home of average speed 100 as i live in the country and theres no traffic lights but pretty much no booting at all just like a normal sunday car cruising, and when i arrived home there was a funny smell and when i opened the bonnet the engine BAY (not just the engine) were extremely hot. the actuall stand that holds the bonnet open was to hot to hold.
Now is this normal??? i notice that there really isnt much room for the heat to be released in the engine bay, but i was just cruising for a good 20 minutes so the cool air should of pushed through some where.
just finally the oil that was used was that magnatec stuff, my dad says, cause the oil sticks more to the inside of the engine it could be holding the heat a lot more than a normal oil that will run down to the sump alot quicker.
thanks all any help and advise would be greatly appriciated.
https://www.sau.com.au/forums/topic/61698-is-this-right-on-my-gtr/
Aslong as the engine didnt overheat then there wont be any damage, sometimes the entire front of the car can get heatsoaked from engine/brakes etc its fairly normal
oil could be a factor, personally i wouldnt use magnatec, its not really designed for high performance turbo engines
I know my car can get quite hot too, its only a GTS. I think thats the way with most imports as they run hotter i think (in a way)... thats probably not true, but they do tend to keep the heat around the engine bay for quite a while (my mates 33 GTS-t that he just bought he was driving it around throughout the day and night - joy rides cus he jus got it) anyways, he woke up the next morning to find that the engine was still warm to touch, not hot in anyway but definately not cold.
rb26dett are known to generate a great deal of heat even when you are cruising leisurely... go motul or something else other than the magnatec stuff.
if you think thats bad... wait till you done 2 laps at the track.. the oil temp needle will be sitting at 12 o'clock easily. sump and oil cooler is the proper way to go :rofl:
Don't let this happen to you! Check your radiator fluid and oils. Also check radiator/intercooler for leaks. What readings are you getting from your temp gauges? How viscous is your oil after a normal drive?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
