***PRICED TO CLEAR!***
:D
The following is all up 4 sale:
R32 gtr rear spoiler(black) - SOLD
R32 gtst rear sway bar - $40
Blitz daul turbo timer - $50
R32 gtst LH quater Pannel - SOLD
R32 gtst LH Head light - SOLD
R32 gtst fog lights - SOLD
R32 gtst front stone guards - SOLD
R32 gtst 4 door rear spoiler (mint) - $100
R32 gtst intercooler with piping - SOLD
R32 gtst dash board - $ 100
R32 gtst climate control - $80
R32 gtst washer bottle - $40
R32 gtst raditor bottle- $40
R32 gtst front brake disks (good cond) - $ 100
R32 gtst LHS indicator (clear) *2 - SOLD
R32 gtst brake master cylinder - SOLD
R32 gtst indicator stalk with surrounding plastics - SOLD(stalk only)
R32 gtst door hinges - $15
R32 gtst bonnet hinges - SOLD
R32 gtst Window wipper motor - $ 20
R32 gtst window wipper arms - SOLD
R32 gtst stock themo fan - $ 40
R32 gtst stock leather steering wheel - SOLD
R32 gtr front bar for gtst - SOLD
call simon on: 0421 466 574
Pm for pics.
Will negotiate on some items
Edited by simmyb
https://www.sau.com.au/forums/topic/61797-r32-bits-n-peices/
  • Replies 132
Posted Images
32 gtr fibre glass front bar (fits r32 gtst) never painted or fitted - $350
Hi,
I am interested in the front bar for my r32 gtst, I am located in the eastern suburbs of melbourne and would like to have a look at it if thats possible.
Where are you located??
:wassup:
Yep below all the tachos etc.. sometimes theres spare buttons there..
"Lower dash: below the instrument cluster there's a black plastic section that has 2 blanking covers (to install switches or whatever) on the left, and one cover on the right"
Heres a pic I scammed off the net.. its from a GTR but you get the idea
Have you put any holes (for gauges for eg) in yours or is it intact?
Have you got a drivers window plastic rain lip for sale at all? (if it will fit a coupe 2d)
Whereabouts are you? Will come have a look after work hours if its ok?
~hellrazorette (for 46n2)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
