The "best" turbo will depend on what application you want it for. You want response, top end power, or what?
It has been covered fairly well in the past. I found these threads to be of the most help. Happy reading.
http://www.skylinesaustralia.com/forums/sh...ight=Trust+2530
Hey anyone know where to get good priced low mount aftermarket manifolds, I have 2530's and might be interested in getting some better flowing manifolds.
Also, opinions on the best dump pipes, I have seen Trust jobs with the collector for turbine and wastegate down quite a way. I also like the Tomei dump design, which I had on my SR, worked wuite nicely.. less collection resistance.. Opinions appreciated.,.
2530's are good street turbo's but also don't look past the N1's even though there are many version . It's right in saying that the stock dumps are very restrictive , my 2530's will be coming off soon to make way for some nice aftermarket dumps atleast and maybe a change in manifolds .
I'd also be interested in ppl's opinions on what the best dump pipe setup is at the moment ? .
As far as manifolds go, I would be interested to see some dyno results for a car that has upgraded from factory manifolds to HKS/ported items.
I wasnt aware that the factory items posed any serious restriction
I am running R34 N1's with the .64 ex housing, still using stock manifolds and dumps making 302.9kw at 17psi. Will be putting the car back on the dyno soon to wind up the boost a bit more and see how much further we can go :D
I would recomend them to anyone wanting a good street turbo setup at a reasonable price. Other than that i know of a few GTR's getting around with Trust T517z's making a comfortable 330kw with stock internals.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
