I have an amp in my current car that i want to use in my next car. It's like a 75RMSx2 channel Sony job (before the x-plode range), not a bad little unit, still works pretty well.
Now a while back I remember I remember it could operate in "bridge" mode as well as the standard setting. Its been about 4 years since I bought it, and the instructions have long since been turfed...but i was just wondering what that means? From what I recall, it was something like I could wire it up so that instead of just running two speakers, I could run the one (or say a subby) at 150watt.
Is this correct? Anybody know what an amp that is "bridgeable" means???
If that is the case that is sweet, buy another new one that can do similar and either run a subby just off the one amp, or run one amp for one speaker and one for the other (me think I need powerful speakers then ~around 350Watt Peak). music power!
https://www.sau.com.au/forums/topic/6215-bridged-amp/
hi dude, this topic took me a while to get my head around when i first started playing with amps, but now wreak my knowledge!!!
When you bridge an amp, each half of the amp sees "half" the load. So if you bridge a 4ohm sub over your 2 channels ( + terminal of one channel and the - terminal of the other channel) your amp will see a total load of 2 ohms. This is why you get doubled power output, as the resistance is less.
This is ample power to run any half decent 12inch sub.
But dude, your not going to use one amp per speaker for your front stage or rear fill! That is crazy, as you need no where near that amount of juice to get your mids and tweets cranking!! It is your sub that requires the power and is why people bridge amps to run them. -if you had a decent set of 6x9's or whateva connected to your sony amp in normal stereo mode (75w per channel is HEAPS of grunt) you would be sure to feel pain in your ears if you turned up the volume.
Consider a decent modern high-po deck, say 50 watts MAX. This deck has about only 22Watts RMS, and these will still crank hard enough for most people. So 75 per channel is loads!
Also your amp may be bridgeable, but you still need to know at what load it is STABLE at. eg it may be bridgeable but not 1ohm stable like RATTUS's amp, in which case if you load it like that you could smoke your amp.
https://www.sau.com.au/forums/topic/6215-bridged-amp/#findComment-93274
Thanks, I am a little more filled in now on what i need to know...
hehe... not always ! I have a 5 year or so old Pioneer deck that puts out 25W RMSx2 as standard - that wasn't always enough when crusing down the freeway with the windows down and that is why I bought the amp - there was a lot of noise loss at that speed and therefore wouldn't go loud enough. When camping as well, its good to have a stereo on wheels - as long as the amp doesn't draw too much power you can get a good 5 hours cd's before the battery drains.
Yup, 75W is loud, however it did distort when you cranked it right up - but that was generally due to my supposedly 200watt (peak) speakers that weren't really able to handle up to that. Generally that was of course much much louder than you could handle just driving around in traffic all day.
Over the 4 years or so, my 16x9's put a bit of a crackling now - prolly too much volume for too long + sun damage from parcel shelf. Anyway, all of that stuff is going in my old car because its pretty outdated... I'm just keeping the amp
https://www.sau.com.au/forums/topic/6215-bridged-amp/#findComment-93791
When looking at stereo equipment, never, never, EVER, judge it by its music/PMPO/peak power ratings. These ratings often mean nothing, it could mean the point at which the voice coil melts! A 200W peak power rated speaker could prolly only handle about 20W RMS. Thats why when you put 75W RMS in to a 200W peak/music rated speaker they distort. 75 RMS is prolly closer to 1000W peak!!
https://www.sau.com.au/forums/topic/6215-bridged-amp/#findComment-94657
Yup, I'm aware of RMS and Peak figures and how you read anything that reads 400watt it ain't 400watt. I read up a bit a few years ago when i bought the stuff, but of course I forget many things!
The 16x9's were Sony you see at 200W and matched fairly well with the amp - so I trusted those figures a lot more than others at the time (going on previous Sony equipment). They were/are good speakers but any speaker over time starts to deteriorate.
Why amps are in RMS and speakers still all in peak I don't know. The foruma I believe is Peak = (RMS * root2) *2 and then some - So 75W peak can drive 220watt or so peak speaker. Correct me if I am wrong.
Of course many don't know that, or actually believe those big numbers! If they were really 200W speakers we'd all be running them in our house, not the car ;-)
https://www.sau.com.au/forums/topic/6215-bridged-amp/#findComment-94715
And our ears would be bleeding! hmmm 200W RMS speakers... I spose they'd go as hard as a car with 200rwkws! NICE!:cool:
https://www.sau.com.au/forums/topic/6215-bridged-amp/#findComment-94817
  • 3 weeks later...
Hey guys, do you know anyone selling an amp rated at roughly 300rms upwards into 1 channel. secondhand, I only have like $300 - $380 bucks. yeah tough ask i know but of anyone is selling something decent let me know. I forked out too much for a Square kicker solo baric and it needs JOOCE
thanks, sorry to hijack,
https://www.sau.com.au/forums/topic/6215-bridged-amp/#findComment-103637
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
