  • Replies 376
Posted Images
I'll take one if you can do it for $150 posted to Melbourne :P
I just checked postage to Melbourne is $16 , i have to register and insure it , so all up would be $156 delivered to your local p.o.
Let me know if you are interested .
o.k. cool , i dont know your setup so you may have to work out some mods to fit it . I know it fits perfect in the r33 spot all you need is a bigger top bracket ( to fit in the 33 spot ) .
Do you have dimensions of the 1200CCA battery?
I need one for a Nissan Exa, just want to make sure it will fit
Cheers
Greg
I didn't say they are 1200 cca , what i said is that they are a copy of the odyssey 1200. they are not 1200 cca they are 1200 ca . They are probably around the 600 cca and about 40 amphour . I believe they are a very good battery , i have one in my r33 gtr and i'll buy one for my 34 when it comes here from japan .
Some forum members have these batteries in their cars , if anyone is not happy with theirs please say so .
The dimentions are : 197x165x170 high al in mm , same size as the odyssey 1200 minus the metal case .
How do they compare performance-wise to the Odyssey? Who makes these? I have a couple of people who are also interested but need more info. Can you provide definite specs?
Charlie.
They are made in China and they are copies of the odyssey 1200 minus the metal case .
I had 1 in my car for about 1 year and its fine .
I have 2 small ones in my jetskis , had them for 3 years now and they perform fine . The original jetski batteries only lasted 2 years .
What about warranty? Will there be a receipt issued? What do they retail for? Brand name?
Sorry for the questions, but the other buyers would like this info.
Also, how soon can we get them?
Also, what are those two rectangular caps for if they are totally sealed units? I have 3 others interested in these.
Thanks,
Charlie.
They are totally sealed and they say so on the case , i cant take a pic of the side of the battery . Its in the boot of my gtr and you have to remove the steel backing to get to it .
Those caps you cant remove , i guess thats were they seal them , not sure but i know you cant remove them .
I cant offer you warranty at that price sorry , yes a receipt will be issued from the supplier ( not from me ) , they don't retail as far as i know .
Its made in China thats all i know dont know brand name.
I'll let you guys know as soon as i get the numbers .
nxtime as you are in sydney you can pick up and pay at the same time if you like .
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
