oh so your the guy who had the car towed up all the way from wollongong. Yeah they are the official repairers for Famous Car insurance and a few other insurance companies.
In that case I better make sure they do their job properly. A workshop is only good as its workers. Like any workshop you ocassionally have a few unhappy customers but overall Tai does a great job. Tai owns the business now. Every car around cabramatta goes to Stevens Prestige.
Hi Andrew :( how you been . Havent forgot about my buddy Nick either :)
Btw Im Minh. :)
Hi Andrew :) how you been . Havent forgot about my buddy Nick either :)
G'day Minh! How's your butt going without me around to kaboom it every now and then? :(
You still got your GTR? I'm going to be selling mine very soon :)
Nah my GTr is with Steve now. He is trying to sell it, why you letting your one go? :)
I drove a 2 door sti around for awhile. I sold that two weeks ago too so I been walking around. Twin leg power. Getting a S15 soon. Just stocker. gotta save for wedding this year. Cant keep getting raped by young thai boys who own skylines I ran out of vaseline. :(
Letting mine go because I don't drive it anymore :) I've moved onto a slow-ass euro car and I might as well sell the GTR and let someone else enjoy it instead of having it sit in my garage gathering dust :)
Yah... S15s are nice :) I can't wait until they drop to $20k-ish and I'll get one for a track bitch :) :) :)
yeah hes the one im dealing with.
im going to try and make an effort to come check teh car out.
just want to make sure im getting the same front bar that i had and also the same grill.
ill only really need a courtesy car if my car is going to take a while to repair.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
