Originally posted by KamikazeR33
jayson i had the redline shockproof in mine $25 a L mind u
and now i have the same stuff u have, and mine crunches slightly into 2nd when cold
Ahhh, cool. It's only for the first 5 mins of driving that it crunches into 2nd, and if I double clutch it it's fine.
Joel - Cool, I might give that stuff a try.
Cheers
Jayson
  • Replies 84
I had a similar problem in my Skyline - a hot-cold gear crunching problem, except that my clutch dropped right to the floor (no friction point) when it was cold and was close to impossible to get into gear.
The problem is because the existing gearbox oil was far too viscous (i.e. thick) for my brass button clutch, and basically when it was cold it got thicker and thicker and theres no room inside the gearbox for the clutch and the gears to engage.
Mechanic just switched gearbox oil to an automatic gearbox oil, because they're much less viscous, so that when they're cold there's room for everyone in the gearbox, hence no crunching.
Yes but auto trans fluid will destroy your box over time. It doesnt contain the extreme pressure additives that gear oil does.. So your gears will start pitting and ur syncros will get knackered sooner or later!! You should try VMX80 instead. Its pretty thin!! I would only use ATF if the box required it..
Btw I tried Nulon G70 in my box. Hardly made a difference and ive done 2000ks on it since. I'll just leave it in there tho. May work for others!
Same Busky2k, I put a tube of Nulon in a few weeks ago and I haven't noticed a difference.
I was told to use Castrol Syntrax in my gearbox, but everyone else seems to use VMX80. Maybe I'll try it seeing as I've already bought it and see how it goes. The guy at Autobarn said it was better for gearboxes in high performance cars..but u never know whether to believe them or not!!! :P
Im using Lightweight Shockproof (Redline) oil. I've done about 600kays on it and it is starting to run really smooth, i really recommend it.
Also, i've said it before, if you can't get the filler bung undone, pull out the speedo sender relay about 10cms behind the filler bung and fill the gearbox from there.
PS Jay, done the diff yet?
Oh crap, sorry Ronin - I forgot to post the results...
Yepp, did it last weekend. I had a good look at taking the diff cover plate off and dicided it was going to be a pain in the butt, so I didn't take it off :P
I managed to get the filler plug out without dropping the exhaust down... JUST.... My exhaust must be a bit different.
Drained the oil using the bottom plug and let it drain for about an hour, then got my finger in the hole (!) and scooped the rest out.
Filled it back up. All went well.
It seems like road noise is down a bit as it's not as noisey in the cabin as it was before. The LS90 oil and the additive I used did loosen the 2 way diff up a little, not a great deal, but I can feel the difference.
All in all I'm pretty happy with it.
J
  • 7 months later...
what was the additive you used in the diff Jay?
I got some of the Nulon G70 stuff and it says suitable for manual transmissions and diffs, including LSD's.
Did the Gearbox last week with Castrol VMX80, but still got the crunchies, so thinking of doing it again with the Nulon additive. A bit of a waste of oil/money, but at least I'll know it's had a good flush.
One thing I noticed with the VMX80 is that it got better the more you drove it. The improvement wasn't straight away that's for sure.
Let it go for 500km and see if it get's better.
The additive that I added to the diff was straight from Nissan. It's what they use in the new Patrol's to stop the diff chattering.
It made a little bit of difference to the 2 way, not a massive difference though...
Apparently the stuff is a friction modifier, so it allows the diff to slip a little more before it locks up.. Maybe...
J
It's pretty much the same as the gearbox.
Drain the old oil by using the bottom drain plug. Then refill using the plug half way up the diff.
I'd say for normal driving about every 50,000km ???
I can't remember the type of oil I used in the diff...
J
  • 9 months later...
Hey all
I tried to change my Gearbox oil on the weekend (first time I've tried in this car) and I could not get the plugs out, either of them. A half inch ratchet does not really fit properly, it is too small. The main problem is the plugs are in there too tight and they have that red sealent on the threads by the looks of it.
Any advice, Please.
What tool should I be using? Any advice on how to get the overtight / glued in plugs out.
Don't want to have send it to a shop for such a basic job. Thanks.
  • 6 months later...
well, first of all, get a socket that will fit, and get under there, with a decent socket, and use the force pretty much.
That red stuff u can see is most likely locktite, and will make it rather hard to undo. but once it starts, u should have no problem. u can also try and squirt it with some wd40 or similar to loosen the parts up.
where did my post go?!? :(
ahh well here it goes again.
I had trouble removing my g/box drain plug with a 1meter extension bar. :(
The car was over the pit and it had all of my weight. The bar was bending.
It eventually came loose and sent me flying backwards and skinned my knuckles on the cement. :(
If the car was only jacked up I would not have been able to remove it.
I was the culprit who did the sucker up prior also. I only used the standard length of the ratchet to do it up.
The R32's don't require a socket, simply use the half inch drive as the plug is female.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
