nice stuff.. unfortunately I had to pull out of this one as I was hoping to be there with my 32 as well :D wish I could have been there. All my car is sorted with my new brakes now, is off for compliance on friday.. So I'm itching to be out there on the March day.
so did any1 see a white 32 gtr there, i was on my way home from work and saw a white gtr on the bruce h'way just past the mooloolaba turn off, thought it mite have been sum1 on here from up the coast that went down. is that autobarn gtst from nambour at all?? does any1 know??
Hey, I was just about to start this thread!!!!
Anyway, thanks heaps to Paul and the rest of the organisers / voulnteers, the day was great fun, and ran like clockwork. Lets hope you can get your car out there next time Paul!!!!
Thanks heaps to the guy who helped me get back on the track (sorry did not get your name) by helping to "fix" the "minor" fuel leak problem I was having. I thought I'd checked every nut and bolt on ther car, I did not even think of the filler cap.
I've alyways said a hammer, a set of multigrips and race tape are the most important tools at a race track.
Anyway, I had a ball, was really happy that I did not break anything :D and I was reasonably happy with my best time (1:12:97) considering it was my first track day with my close to stock R33. I might have to read up on racing lines though:)
I think I'll be directing a bit of money torwards the handling side things (after I recover from the accociated costs of the track day!!!), a set of lower coil overs and bigger front disks would be nice.
How cool was that Porsche, that thing could handle!
Thanks to my pit crew I have a few pics (below) with commentary and all.
I'm keen for the next one.
Thanks guys. I had a great day too, even if my car was not ready. It definately will be ready for the next one. Decided no more last minute mods as my new years resolution.
The timing gear went great.
It was mostly the guys from www.TeamTurbossRacing.info who ran the pits etc.
For anyone who is interested, these are the results from the day. Our timing gear is fully electronic at 1/100th of a second.
Porsche GT3, 01:02.93
R33 GTST, 01:03.86
Silvia, 01:03.90
R34 GTS, 01:04.84
Westfield SEI, 01:05.36
Lotus 340S, 01:05.60
Silvia, 01:06.81
VX SS, 01:07.73
WRX, 01:08.15
BMW 2002, 01:08.52
WRX, 01:08.55
R33 GTST, 01:08.56
R33 GTST, 01:08.81
Silvia, 01:09.94
Integra, 01:09.95
CV8 Monaro, 01:10.56
BMW 325, 01:11.63
WRX, 01:11.76
GT-4, 01:12.09
GTS4, 01:12.24
Silvia, 01:12.43
R32 GTST, 01:12.93
R33 GTST, 01:12.97
BMW 323i, 01:13.15
MX-5, 01:13.27
250 EWQ, 01:13.57
R32 GTST, 01:14.14
R32 GTST, 01:19.76
OMG who was that??
I think that was the Silver Autobarn car, it hammered until something let go (oil leak?) and they retired. I was standing at the end of the main straight on the lap it happened - it did not sound so good:(
horrific brake shudder. next mod. brakes!!
Brakes... You've heard my brakes :D As far as I can tell, Skyline brakes either shudder, squeel, make bucketloads of dust, or all / some of the above...
Good mod though... I can reccomend the DBA 4000's and RB74 pads... Just make sure you put the anti squeel shims back in :)
i wouldn't be worried about regular brake shudder but this is really too bad to put up with any longer. imagine your traveling along at anything above 100, you apply the tiniest bit of pressure to the brake pedal, the shudder is so bad the steering wheel is practicly wrenched from your sweaty little hands. i'm thinking this is not the usual skyline problem
now i'm off to defrost the credit card :)
hey guys if the silver auto barngtst is from nambour , he compete's in trhe noosa hill climb every year, it has a few mods to it. not sure what though id say it has susspension work for sure. my mate works up there at Auto Barn and its his bosses car. the oil bit didnt sound too good though. oh well.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
