  • Replies 163
It's funny they think RB26 transplant = GTR
Twin Turbo on a RB20/25 = GTR
yet seem to conveniently forget little things like Atessa, wider flared guards for wider rubber, getrag gearbox, center guages etc etc.... the list goes on.
As I said before if you have a beast of a GTST be proud of it, take joy in the fact that people will underestimate it's potential and speed. Enjoy the looks on others faces when your GTST blows them off the track. Don't devalue all the work you have put into it, by trying to claim it is something it is not.
If the maroon skyline has Rb26 in gtst then its got the right to have the badge :P
Yes or No ?
correct me if im wrong but last i heard off him it still had the 25....not that it would justify it anyway
say you have a dead RB26 engine....and you can't affod to buy another engine and your mate were like donating an RB25 to fit into your GTR..and you agreed to do so.
what would you call that one ? still a GTR ?
hahahahaha :P
id call it rice
omg....*hides head in shame*
my gtst has a gtr badge...but tht was there on the gtr bodykit when i bought the car.....i dont lie and say i have a gtr, cuz im not tht sad, and i dont drive her as if she was a gtr either, so am i still a shame to the skyline community??
i could take if off...but then that part of the bumper will b ugly, i basically have it so its not so ugly *rice*
I had a GTR key, for an S13 with an rb25de(TT), frying 600rwhp. Am I rice? :(
lol no your not rice cause anyone that goes to the the trouble of squashing an rb26dett into an s13 deserves a medal (in your case it was a GTR Key)
you would have been if you put a gtr badge on the back though:)
of course ....only coz you wore the key around your neck hehehehe jk
:rofl:
if i tatoo gtr on my right asscheek then id be the rice king
what makes a GTR a GTR is a car that rolls off the factory floor in japan as a Nissan Skyline GTR
there is no copy, no equal, no better!!!!
unless it rolled off the jap floor a GTR it aint a GTR
:werd:.....btw josh's s13 wasnt a 26 it was a 25 twin turbo that was basicly a 26 in size anyway :( confused?
so how many R33 GTSt's with Nismo 400R kits are you gonna go up to and say "NOOOO you don't have a 400R, you're a ricer and I have a brain the size of my balls" to?
I was I must admit quite amused by the sheer number of GTSt's in brissy that had GTR badges on em. But get off it, what right do you have to dictate what other people do with their cars... if you don't like seeing it, close your eyes.
You aren't the Nissan police.
whoa...this has gone further than I thought...
And I knew Harun's old car would be on the list...
It is shameful, we are just letting people know its like sticking a Type R badge on a 120Y...
We are NOT the Nissan police as this country has enough bacon already. People just need to realise that it is gay...
but... 120ys are dattos... Just like GTRs...
Anyway, I do belive the only way to solve this problem is to go to all the autobarns, repcos, etc round the country and confiscate all their badges with type R on them, or GTR. Its the ONLY way!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
