thanks guys, I got it checked today... there seems to be fuel coming from the side of it..I don't know if that's fixable but the guy advised me to get it tested first...he thinks I may have to replace the injector, I'll pull it out soon and give it to them...will know more soon.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1194828
I had a leaky injector 3 days after I first got my baby. I took it to DynoTune and they had it for 4 days, it turned out to be a bodgy o-ring and Nissan sent them a set of new ones......except...... they sent one wrong one out of the six, but they didn't work this out til I'd gone out and got another set of injectors......
So if you need a stock r32 rb26 injector just pm me.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1195062
pm sent
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1195087
thanks for the reply mjfawke,  Is there anything I need to know before removing them? I don't want to damage it any further....can I just take the fuel rail off, then twist the injector anticlockwise or is there a special way to take them off?
Nah - twist and pull, the O-ring will stay on the end of the injector. The manifold seals will probably stay with the manifold, so be careful getting them out (scribe/small screwdriver etc) - you don't want a leak.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1195309
ok... so today I decided to pull the injectors out and i think i've found the problem, on the front of the injector there's a green plastic bit that looks sort of like a nozle... along the side of that is this crack probably a bit smaller than 1cm... it doesn't reach the main body of the injector though, other than that the rest of the injector looks pretty good and the O-rings look ok....now im just wondering if that plastic bit is replaceable or not... gotta wait till monday i guess :D
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1196019
pm sent
Hey there GM,
Sorry I have got back to you earlier but I had a very busy weekend and haven't had a chance to check the forums. I've PM'ed you with my mobile number, just give me a buzz when you get it. How many injectors were you after?
Cheers,
Brad
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1198167
can anyone suggest someone to test my injector system as I dont think they are firing and I dont have a tester (light).
Plus anyone wont to finish getting my turbos off? what a shit of a job! they are down to the oil lines and there is like 4 on each turbo. they are all thats holding them in.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1198272
1. Try Geoff at Capital Injector Cleaning - see Jayce's post here for the number. He's been pretty good so far.
2. Sorry no. Prob would've if you'd have sold me that gear knob. LOL J/K.
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1198371
finally got the injectors checked...and there pretty much screwed..well 2 of them anyway, it's all sorted now, thanks oz32 for the injectors, there working good by the way..no problems :mad:
Hey stirlo, I got the injectors checked at tugg car care... I don't know if there any good as they just quickly checked them and said they couldn't be fixed.
not too sure about the turbos but isn't there two bolts holding each line in that you just need to undo? I can give ya a hand..don't know how much help I'll be though :confused:
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1200426
finally got the injectors checked...and there pretty much screwed..well 2 of them anyway' date=' it's all sorted now, thanks oz32 for the injectors, there working good by the way..no problems :(
No probs GM :) Glad to have been able to help!! and great to hear that you're back on the road!
Cheers,
Brad
https://www.sau.com.au/forums/topic/63455-leaky-injector/#findComment-1201151
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
