  • Replies 134
John rang me today. Someone who booked with him didn't turn up. I won't say who, but PLEASE guys, if you book in, make sure you turn up.
He's giving us all a good deal, the least you can do is turn up when you book, or give him a courtesy call.
He refused work because he had a booking.... doesn't reflect well on me or the club don't u think?...
thanks guys
Mate you can get ur windows done cheaper then that ,, i have a R33 that i tinted myself .. but then again i have been tinting for over 12yrs ,,.. and my advice is dont go to a tintacar dealer cause they will charge u heaps.. My car is done in 20% from rear window to the small quaters and the front doors are done in 30% and its all legal..
of course you can.
but there are several things to consider
1) Quailty of the tint
2) The fact that this bloke does run a business and does need to earn a living
i mean sh|t, you want the bloke to make $10-$15 off each car for an hours work?
come on.........
WEST - BL00DY HELL MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:rofl:
Yeap i called back but i was engaged. How does this sound i got out of the house at 7,30 am and got defected 15mins after that? I was running around like a chook try to get it off and call him back on the tuesday to say sorry and explain stuffs.
Shouldn't have freaking go toward that area.
I hope you are all happy with the Tints so far, couldn't be fudged reading the entire thread.
Brett at tint a car in Camberwell is the tint master, i say that with authority, any one that knows me knows that when i recommend some one they are damn good or I would just shut my mouth and not post.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
